Connection issue from Docker Image (requests.exceptions.ConnectionError)
idm.ipoac.ch
certonly --dry-run -d idm.ipoac.ch --agree-tos -m email@example.com --authenticator dns-infomaniak -v -n
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x70f58be393d0>: Failed to establish a new connection: [Errno -3] Try again'))
none
Proxmox 8.2.2 running an Alpine Linux 3.19 LXC Container which in turn runs a modified Docker Image running Alpine Linux 3.18 which is based on the official Docker Image
myself
no
2.11.0
Issue while running container
my setup might be a bit convoluted and the issue may not be directly related to LetsEncrypt / Certbot, but I am still hoping someone can offer some ideas for solving my problem.
When I run the container on my server, I do that via rootless podman kube play, I get the following error:
BUT
  • When running the exact same image with the same parameters on WSL openSUSE Tumbleweed the certificate is issued without problem.
  • When running the exact same image on the exact same host, but interactively and execute the certbot certonly command, the certificate is issued without any issues as well.
    podman command:
    lxc: ~$ podman run --rm -it --entrypoint ash  ghcr.io/fipoac/certbot-dns-infomaniak:latest
    /opt/certbot # certbot certonly --dry-run -d idm.ipoac.ch --agree-tos -m email@example.com --authenticator dns-infomaniak -v -n
    Plugins selected: Authenticator dns-infomaniak, Installer None
    Simulating a certificate request for idm.ipoac.ch
    dns-01 challenge for idm.ipoac.ch
    Waiting 120 seconds for DNS changes to propagate
    The dry run was successful.
I'm thankful for any solution approaches
That is usually a problem with the DNS Resolver running in that system. In fact, instead of "Try again" it usually says something about the name not resolving.
See if dig works in that same container for any domain name. Or if curl works to any other destination (like https://google.com). These probably don't work either.
Thank you for your answer
Dig from the container resolves correctly:
/opt/certbot # dig acme-v02.api.letsencrypt.org
; <<>> DiG 9.18.24 <<>> acme-v02.api.letsencrypt.org
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 9839
;; flags: qr rd ra; QUERY: 1, ANSWER: 3, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1232
;; QUESTION SECTION:
;acme-v02.api.letsencrypt.org.  IN      A
;; ANSWER SECTION:
acme-v02.api.letsencrypt.org. 4942 IN   CNAME   prod.api.letsencrypt.org.
prod.api.letsencrypt.org. 117   IN      CNAME   ca80a1adb12a4fbdac5ffcbc944e9a61.pacloudflare.com.
ca80a1adb12a4fbdac5ffcbc944e9a61.pacloudflare.com. 113 IN A 172.65.32.248
;; Query time: 201 msec
;; SERVER: 10.0.2.3#53(10.0.2.3) (UDP)
;; WHEN: Fri Jun 07 14:21:32 UTC 2024
;; MSG SIZE  rcvd: 155
wget is available via busybox and this does work too:
lxc:~$ podman run --rm --entrypoint ""  ghcr.io/fipoac/certbot-dns-infomaniak:latest wget https://acme-v02.api.letsencrypt.org/directory
Connecting to acme-v02.api.letsencrypt.org (172.65.32.248:443)
saving to 'directory'
directory            100% |********************************|   746  0:00:00 ETA
But if I put the same command alone in entrypoint.sh it does not work.
So it seems, it is not a problem with LetsEncrypt or Cerbot but with podman on Alpine Linux LXC handling entrypoints differently than commands.
Thanks for pointing me in the right direction.
