Error when trying to renew certificate using docker certbot
My domain is: ma7gdp.duckdns.org
docker run -it --rm --name certbot -v ":/etc/letsencrypt" -v ":/var/lib/letsencrypt" -p "28443:443" -p "28080:80" certbot/certbot certonly -d ma7gdp.duckdns.org --standalone
An unexpected error occurred:
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fecb1639990>: Failed to establish a new connection: [Errno -3] Try again'))
My web server is (include version): official certbot docker container image
The operating system my web server runs on is (include version): Debian host
My hosting provider, if applicable, is: n/a local home server
Thanks in advance for any help.
Cheers.
JFYI I ran the debug here: Let's Debug and it was showing as OK, so I am pretty sure it is not a firewall issue.
I just stood up a temporary nginx server on the same ports via docker to run this debug, but it is no longer running incase anyone tried to run the debug test again.
where port 28xxx proxyed to? unless port ma6gdp..duckdns.org:80 from outside goes to certbot, it won't work=
you may better to use other client
If you hit 80 from external it is forwarded to 28080 and picked up by certbot container and port mapped back to 80. This all worked ok for the last time I renewed, so not sure what is happening.
It seems to have trouble to make an outgoing connection to the ACME API.
That said, I don't know anything about Docker, so no idea on how to debug or fix that.. Perhaps it's as simple as the error message suggest: try again.
Well if in doubt then reboot I guess. Seems to have done the trick. I made no changes, just rebooted and it started working. Not great when that happens as you never find out the real cause, but happy its working :slight_smile: Thanks all for replies.
