Requests.exceptions.ConnectionError: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7ff299f5b850>
cutegirlsinshorts.org
certbot certonly
An unexpected error occurred:
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7feb86ee24a0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
OpenLiteSpeed 1.7.16
Linux
#1 SMP Thu Dec 15 20:31:06 MSK 2022
OpenLiteSpeed (EC2 Instance launched on AWS)
Yes
Yes
1.21.0
p.s. I went to https://check-host.net/ and tried all the tabs. They all responded with normal statuses. But when I went to try the "Ping" tab, all results came up as "Result 0/4 traceroute"
Hi @bobbb23332,
This error suggests that your server can't make the necessary outgoing connection to the Let's Encrypt API server. Can you think of a reason why that could be? Is there any firewall or configuration that you would expect to be blocking outgoing connections from your server?
Can you try something like this?
curl -v https://acme-v02.api.letsencryp.org/directory
I commonly see such DNS resolving errors by misconfigured Docker instances.
Could it be the EC2 instance? Does the EC2 have the ability to block these operations coming from this server? If so then maybe it can be a port forwarding issue I don't know. I checked security groups and ports 22, 80 and 443 are all allowed.
I ran curl -v https://acme-v02.api.letsencryp.org/directory and this is the result:
* Could not resolve host: acme-v02.api.letsencryp.org
* Closing connection 0
curl: (6) Could not resolve host: acme-v02.api.letsencryp.org
Oops, try again with the missing t in letsencrypt added?
Try it this way:
curl -v https://acme-v02.api.letsencrypt.org/directory
I received this:
Please fix your systems DNS resolving capabilities and try again after DNS has been fixed.
Is this what you are talking about? I have these DNS settings set where my domain was bought from:
No, that's the DNS settings for your domain. That's something else than the DNS resolving capabilities of a system. See for example stuff like curl - amazon ec2 instance unable to resolve host - Stack Overflow
So I'm guessing the area I need to be checking is the server of the VPS? I bought this from OpenLiteSpeed which is the VPS hoster which I used to launch an EC2 instance. Is this where I should fix the DNS resolving issues ?
Probably.
(oops!)
I have found the reason for this, my AWS account services was limited by the AWS support team due to a recent compromise in security credentials. Kind of a bummer that they don't explicitly mentioned the services that were affected! It is working now.
