An unexpected error occurred: requests.exceptions.ConnectTimeout: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at
My domain is: emitechno.com
My web server is (include version): nginx:1.17
The operating system my web server runs on is (include version): i use docker (ubuntu 20.04)
any suggestion?
Hi @devops-SOLU,
How is your server connected to the Internet?
Is it possible that your Docker configuration, or a firewall setup, is preventing or limiting outbound network connections?
The Let's Encrypt client application needs to be able to make an outgoing connection to the Let's Encrypt API in order to request certificates.
i can ping google.com.
i dont preventing or limiting outbound network connections
Can you try with curl -v and see which IP address is being used?
What does the routing table look like?
netstat -nr
This part seems flawed:
Why are those real Internet networks in your routing table?
i use docker, and this docker network
Again, why it is using REAL INTERNET networks?
ARIN Whois/RDAP - American Registry for Internet Numbers
ARIN Whois/RDAP - American Registry for Internet Numbers [one used by LE]
i dont know, i use default by docker network
Well, it seems like it is part of the (routing) problem.
what can i do?
I'd go ask on a docker forum about this routing issue.
Otherwise....
To obtain a cert and ignore the incorrect routing, you could:
  • switch to DNS-01 authentication
  • do the HTTP-01 authentication on another instance or on the host
thanks for the advice and information
Cloudflare, the CDN used by LE, currently seems to be using a 172.x.x.x IP address. Sometimes people route the 172.16.0.0/12 private IP space as 172.0.0.0/8, which would include the Cloudflare address too. Which is bad. So that might also be something to look into, private IP space routing.
