My domain is: tangohub.app
I ran this command: $sudo certbot -v -i nginx certonly --dns-route53 -d *.tangohub.app
Plugins selected: Authenticator dns-route53, Installer nginx
Requesting a certificate for *.tangohub.app
dns-01 challenge for tangohub.app
Reloading nginx server after certificate issuance
Certificate is saved at: /etc/letsencrypt/live/tangohub.app-0001/fullchain.pem
Key is saved at: /etc/letsencrypt/live/tangohub.app-0001/privkey.pem
This certificate expires on 2023-01-03.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
- Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
- Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
My web server is (include version): Nginx
The operating system my web server runs on is (include version): Ubuntu
My hosting provider, if applicable, is: AWS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): reza@www:~$ certbot --version
certbot 1.31.0
Hi there, The issue is I am not sure my configuration is correct. Because I am using www.tangohub.app and staging.tangohub.app, trying to use a wildcard, I use *.tangohub.app in the configuration. Also, I don't know if the SSL certificate is written on the Nginx for each website. Would you please help me with this issue?
