It seems this is a known issue. SO I disabled it and it is working.
I am just curious. What did you disable exactly? Because ipv6only=on
is the default anyway for an IPv6 listen statement
I'm not doubting you. I would just like to be clearer for future similar problems. Thanks
Mike, I am far from to be expert and I assume that what I did, disabled the ipv6
So the line looks like this:
listen [::]:443 ssl; #ipv6only=off; # managed by Certbot
Thanks. That's interesting.
No, your new statement does not disable IPv6. That is set with the [::]:
preceding the 443 ssl;
Your info after the ;
is marked as a comment so is now ignored.
There was a similar report about a stray ipv6only=on at the certbot github but it never got sorted. Yours is even more interesting in that you only have the one HTTPS server block (at least per the nginx -T in post #11).
Seems very strange but Rudy's intuition was on point. Perhaps he can shed more light on the circumstances.
I'd like to experiment with a fresh upload of an nginx -T if you don't mind.
sudo nginx -T >nginx-T2.txt
You can't use "ipv6only=on
" more than once anywhere in the nginx
configuration.
Thanks for indulging me.
I understand now. I didn't look at the posts with the second server block manually cloned from the first one. I only looked at the earlier nginx -T
which just had the one.
Still, I'd forgotten you can't do that Good catch
