I have two domain www.example.com
www.abc.in
and both are pointing to same ip and for one domain i already configured wild card certificate now i want to configure ssl for other domain too. so is it possible through one certificate for both domain?
Failed authorization procedure. abc.in (dns-01): urn:ietf:params:acme:error:dns :: DNS problem: query timed out looking up TXT for _acme-challenge.agamiecom.in
Domain: agamiecom.in
Type: None
Detail: DNS problem: query timed out looking up TXT for
_acme-challenge.abc.in
Command what i run :
sudo certbot --server https://acme-v02.api.letsencrypt.org/directory -d abc.in --manual --preferred-challenges dns-01 certonly
For example.com i already get the TXT Record . So i'm running only for abc.in. or have to combine and run for both together ?
Your domain is having issue responding to queries.due to a misconfigured DNS settings.
When let's encrypt query your domain, dreamhost.in redirects to cloudflare... and cloudflare doesn't provide a answer to the query, hence let's encrypt timed out.
Is that an expected behavior?
Do you mean to use cloudflare as DNS provider (maybe as well as cdn)?
I have corrected our dns misconfiguration and also removed old wildcard ssl certificate for one domain and tried to setup for multidomain wildcardssl certificate. Still i’m getting error mentioning below command as well as error:
Press Enter to Continue
Waiting for verification…
Failed authorization procedure. example.in (dns-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.example.in
Domain: example.in
Type: None
Detail: DNS problem: NXDOMAIN looking up TXT for
Your account credentials have been saved in your Certbot
The misconfiguration issue seems to be resolved, however, could you please verify if you have the right domain?
(Run nslookup _acme-challenge.agamiecom.in on Windows machine, or go to a text record testing site try to pull the verification token as a text record from required validation domain)
I Run nslookup _acme-challenge.agamiecom.in on Windows machine. it is replying local ip.
Please give solution or reference link to setup multi domain wild card ssl certificate with nginx.
