Hi folks,
I reached the ratelimit for a domain.
Is there a way to check the remaining time for obtaining new certificates?
Thanks,
Sairahcaz
Hi folks,
Thanks,
Sairahcaz
Hi @Sairahcaz,
You can check the issued certs for your domain at https://crt.sh then count the last 20 issued certs, take the first issued of that 20 certs, check when it was issued and add 7 days to it and you will have the date when you could issue a new cert.
If you use Linux, you can also use the command line tool lectl https://github.com/sahsanu/lectl and check the domain from command line, something like
./lectl -s yourdomain.tld
and it will show the issued certs for yourdomain.tld and *.yourdomain.tld. If you have reached the 20 certs per week limit you will see at the bottom when you could issue a new cert:
Sorry, you can't issue any certificate, you already issued 20 certificates on last 7 days
You could issue next certificate on [Here the date]
Cheers,
sahsanu
what is this magic
Thanks for Sharing
Wow, very nice. Thank you very much!
