Certification problem for noob [duckdns]
My domain is: edadamvpn.duckdns.org
I ran this command: Ran install script which I do not quite understand but it ends in
  • no certificate-
  • no certificate-
My web server is (include version): Not sure here, its a VPS (server) don't think there is a web server running.
The operating system my web server runs on is (include version): Ubuntu 22.04
My hosting provider, if applicable, is: https://softshellweb.com/
I can login to a root shell on my machine (yes or no, or I don't know): yes (ssh)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): don't know what this is
What steps do I have to take to solve this?
The install script you are referring to could be anything at all, do you have a guide you were trying to follow?
I hope this helps
Hi @EdmundDuckDuck, and welcome to the LE community forum :slight_smile:
While we wait for your answer... I see that HTTP+S connections are being refused:
curl -Ii http://edadamvpn.duckdns.org/
curl: (7) Failed to connect to edadamvpn.duckdns.org port 80 after 14715 ms: Connection refused
curl -Ii https://edadamvpn.duckdns.org/
curl: (7) Failed to connect to edadamvpn.duckdns.org port 443 after 120 ms: Connection refused
[that may be part of the problem]
And DuckDNS was (is?) having issues
See Certbox shows a different TXT from dig - #4 by Bruce5051
I guess there is nothing started on my server that listens to port 80.
Is there a web server installed?
What are you going to use the cert for/with?
No web server. I lwant to install a VPN
Ok, we can help you get a cert for that.
The simplest way is to use HTTP authentication to validate the FQDN and obtain a cert.
For that, you will need to open HTTP [TCP port 80] through the firewall(s).
Then run the ACME client in standalone mode.
Using the online tool Let's Debug yields these results https://letsdebug.net/edadamvpn.duckdns.org/2274700
ANotWorking
Error
edadamvpn.duckdns.org has an A (IPv4) record (193.160.96.194) but a request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address.
Get "http://edadamvpn.duckdns.org/.well-known/acme-challenge/letsdebug-test": dial tcp 193.160.96.194:80: connect: connection refused
Trace:
@0ms: Making a request to http://edadamvpn.duckdns.org/.well-known/acme-challenge/letsdebug-test (using initial IP 193.160.96.194)
@0ms: Dialing 193.160.96.194
@28ms: Experienced error: dial tcp 193.160.96.194:80: connect: connection refused
IssueFromLetsEncrypt
Error
A test authorization for edadamvpn.duckdns.org to the Let's Encrypt staging service has revealed issues that may prevent any certificate for this domain being issued.
193.160.96.194: Fetching http://edadamvpn.duckdns.org/.well-known/acme-challenge/-mcBQArQi9yY6Ke9m6K2EMy6gDfg5wbtjnVA7xoti1M: Connection refused
Edit
And
https://dnsviz.net/d/edadamvpn.duckdns.org/dnssec/
" DNSSEC configuration invalid
The DNSSEC configuration is invalid. This will prevent users who are relying on validating DNS servers (e.g., Google DNS) to get any DNS responses for this domain name."
Sounds like a good time to switch to another DDNS provider.
I agree! :slight_smile:
I'd say they're "a dime a dozen" - but they're actually even less than that [FREE!].
Thank for the responses guys. Suddenly the error disappeared and now it is back again.
Don't know what to do next.
Maybe switch to a diffferent DNS provider? Although you would need to buy your domain name. Try Cloudflare they also offer DDNS if you need that https://www.cloudflare.com/learning/dns/glossary/dynamic-dns/
OR
Try using another FREE DDNS service.
