Setting up SSL certification for test domain with private IP
adnetpub1.duckdns.org
# certbot -v --nginx --test-cert
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: adnetpub1.duckdns.org
2: www.adnetpub1.duckdns.org
Requesting a certificate for adnetpub1.duckdns.org and www.adnetpub1.duckdns.org
http-01 challenge for adnetpub1.duckdns.org
http-01 challenge for www.adnetpub1.duckdns.org
Challenge failed for domain adnetpub1.duckdns.org
Challenge failed for domain www.adnetpub1.duckdns.org
  Domain: adnetpub1.duckdns.org
  Type:   dns
  Detail: no valid A records found for adnetpub1.duckdns.org; no valid AAAA records found for adnetpub1.duckdns.org
  Domain: www.adnetpub1.duckdns.org
  Type:   dns
  Detail: no valid A records found for www.adnetpub1.duckdns.org; no valid AAAA records found for www.adnetpub1.duckdns.org
NGINX version 1.22.1
Centos stream 9
no
certbot 2.6.0
I'm trying to create a test Letsencrypt SSL for a web server that would host "adnetpub1.duckdns.org" in an internal private network using a private IP (as opposed to a public IP). I'm getting the error above"
  Type:   dns
That isn't going to work. In order to validate your control of the domain, Let's Encrypt needs to be able to connect to your server--which means they need a public IP address that will reach your server.
Have a look here: Certificates for localhost - Let's Encrypt
You could also consider the DNS-01 challenge of the Challenge Types - Let's Encrypt
That error is to be expected.
Please read
to learn why your method using the http-01 challenge doesn't work with local IP addresses.
There is a third party DNS plugin for DuckDNS available at GitHub - infinityofspace/certbot_dns_duckdns: Plugin for certbot for a DNS-01 challenge with a DuckDNS domain.. That plugin is also available on snap apparently.
