Certificates renewing issue, need help understanding the hint messages
Hello,
I just found out that my certificates renewing isn't working. When I run sudo certbot -v --dry-run renew, I get the following:
Processing /etc/letsencrypt/renewal/cloud.kosmopolis.ca.conf
Certificate is due for renewal, auto-renewing...
Simulating renewal of an existing certificate for cloud.kosmopolis.ca
http-01 challenge for cloud.kosmopolis.ca
Using the webroot path /var/www/_letsencrypt for all unmatched domains.
Challenge failed for domain cloud.kosmopolis.ca
  Domain: cloud.kosmopolis.ca
  Type:   unauthorized
  Detail: 135.23.198.195: Invalid response from https://cloud.kosmopolis.ca/.well-known/acme-challenge/v_R-oFmqhoaYDLGj6py6qz8Ap6hw_ojoNNTFE22vcbg: 404
Failed to renew certificate cloud.kosmopolis.ca with error: Some challenges have failed.
Processing /etc/letsencrypt/renewal/collabora.kosmopolis.ca.conf
Simulating renewal of an existing certificate for collabora.kosmopolis.ca
http-01 challenge for collabora.kosmopolis.ca
Challenge failed for domain collabora.kosmopolis.ca
  Domain: collabora.kosmopolis.ca
  Type:   unauthorized
  Detail: 135.23.198.195: Invalid response from https://collabora.kosmopolis.ca/.well-known/acme-challenge/beGEcmzyxrE2YkGWGxl7lC1A8G6_xLBqyvOD35ASl5I: 404
Failed to renew certificate collabora.kosmopolis.ca with error: Some challenges have failed.
Processing /etc/letsencrypt/renewal/kosmopolis.ca.conf
Simulating renewal of an existing certificate for kosmopolis.ca and www.kosmopolis.ca
http-01 challenge for kosmopolis.ca
http-01 challenge for www.kosmopolis.ca
Failed to renew certificate kosmopolis.ca with error: Missing command line flag or config entry for this setting:
Input the webroot for kosmopolis.ca:
All simulated renewals failed. The following certificates could not be renewed:
  /etc/letsencrypt/live/cloud.kosmopolis.ca/fullchain.pem (failure)
  /etc/letsencrypt/live/collabora.kosmopolis.ca/fullchain.pem (failure)
  /etc/letsencrypt/live/kosmopolis.ca/fullchain.pem (failure)
Running post-hook command: /etc/letsencrypt/renewal-hooks/post/nginx-reload.sh
Hook 'post-hook' ran with error output:
3 renew failure(s), 0 parse failure(s)
I see the error messages and the hints, it says there is something wrong with the "challenges", maybe related to "webroot paths", but I don't know what to do with that. Any clue?
Thanks for your support!
Web server: nginx 1.22.1
OS: Debian 12
Certbot: 2.11.0
UPDATE:
I did the following and got 1 certificate out of 3 to successfully renew: I added the line webroot_path = /var/www/nextcloud to the /etc/letsencrypt/renewal/cloud.kosmopolis.ca.conf file, and it seems to work.
But this domain is a Nextcloud instance, and it does have a ".well-known" directory. For the other domains, there is no such directory in their web roots. The kosmopolis.ca domain web root is /var/www/kosmopolis.ca/, but inside there is only a single index.html file, that's it. collabora.kosmopolis.ca is a domain for a CollaboraOnline server, I don't think it has any "web root" directory... What should I do?
Thanks again.
Hello @renbus, welcome to the Let's Encrypt community. :slightly_smiling_face:
This is saying the expect response wasn't provided (actually File Not Found).
This is Hinting at a possible reason that the content being served location might not match the location that the Certbot option --webroot-path/-w is pointing to.
Edit:
To assist debugging you could add a file, say HelloWorld, to the location that you believe should serve
https://cloud.kosmopolis.ca/.well-known/acme-challenge/HelloWorldfile
Create the HelloWorld file with something like this (to that actual root of the serving location)
sudo echo HelloWorld > .well-known/acme-challenge/HelloWorldfile
sudo chmod 744 well-known/acme-challenge/HelloWorldfile
That doesn't actually work, just use an editor and make sure the file permissions readable by the server (something line chmod 644 should make sure everyone can read the file)
This does work:
sudo /bin/bash -c "echo HelloWorld > ./.well-known/acme-challenge/HelloWorldfile"
sudo /bin/bash -c "chmod 644 ./.well-known/acme-challenge/HelloWorldfile"
And then verify, web browser or curl, that https://cloud.kosmopolis.ca/.well-known/acme-challenge/HelloWorldfile is serving up the contents, in this case `HelloWorld with a HTTP Response Code of 200 (possibly any Success HTTP response status codes - HTTP | MDN).
If the contents are being served ideally the HTTP Response code of 404 (but should be in Client error HTTP response status codes - HTTP | MDN).
UPDATE:
Testing and debugging are best done using the Staging Environment as the Rate Limits are much higher.
Also note that the is a redirection from HTTP to HTTPS as demonstrated here
Ask for the HTTP challenge and its Response
$ curl -Ii http://cloud.kosmopolis.ca/.well-known/acme-challenge/sometestfile
Server: nginx
Date: Tue, 11 Jun 2024 21:42:00 GMT
Content-Type: text/html
Content-Length: 162
Location: https://cloud.kosmopolis.ca/.well-known/acme-challenge/sometestfile
We get a redirect (i.e. Location: above) to HTTPS
and here is the HTTPS Response
$ curl -k -Ii https://cloud.kosmopolis.ca/.well-known/acme-challenge/sometestfile
HTTP/2 404
server: nginx
date: Tue, 11 Jun 2024 21:42:12 GMT
content-type: text/html; charset=utf-8
content-length: 146
referrer-policy: no-referrer
x-content-type-options: nosniff
x-frame-options: SAMEORIGIN
x-permitted-cross-domain-policies: none
x-robots-tag: noindex, nofollow
x-xss-protection: 1; mode=block
It looks like you sorted out most of the problem. You may have an unused cert remaining since two certs have your base name in it
You may want to review your nginx config and see which cert files it actually uses from this list
sudo certbot certificates
and then delete the one(s) you don't need with
sudo delete --cert-name (name)
Where (name) is the cert name from the certificates list.
Your recent cert history
