Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=qfrcem.co.uk), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: qfrcem.co.uk
I ran this command: sudo certbot --apache -d qfrcem.co.uk -d www.qfrcem.co.uk
Your existing certificate has been successfully renewed, and the new certificate
has been installed.
The new certificate covers the following domains: https://qfrcem.co.uk and
https://www.qfrcem.co.uk
https://www.ssllabs.com/ssltest/analyze.html?d=qfrcem.co.uk
https://www.ssllabs.com/ssltest/analyze.html?d=www.qfrcem.co.uk
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/qfrcem.co.uk/fullchain.pem
/etc/letsencrypt/live/qfrcem.co.uk/privkey.pem
Your cert will expire on 2019-06-28. To obtain a new or tweaked
with the “certonly” option. To non-interactively renew all of
your certificates, run “certbot renew” -
Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
My web server is (include version): apache2
The operating system my web server runs on is (include version):ubuntu 14.04
My hosting provider, if applicable, is: AWS
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):using SSH
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
