Certificate Renewal Issue
My domain is: www.sanssoucie.ca
I ran this command: I am not techy and have no idea.
My web server is (include version): Bluehost?
My hosting provider, if applicable, is: Bluehost
What's the exact "issue" with regard to renewing?
I can see your certificate is indeed expiring on 04-04-2024 and thus according to the recommendations from Let's Encrypt usually would have been renewed by now.
That said, do you encounter some error somewhere? If so, what error?
If you don't know if you have root access, you must have some other way of managing your website? This is usually done with a control panel. Popular panels are cPanel or Plesk for example.
Could it be Squarespace perhaps? Because the webserver identifies itself as "Squarespace" and the IP address of your website is also from Squarespace.
It looks like only your DNS is hosted by Bluehost.
I keep getting an error saying the certificate expired in 2018. when I am in the CPanel.
Well, that's clearly not the case if you go to your website and check the certificate.
Is that cPanel the control panel for your actual website? Or perhaps just for your DNS with Bluehost? (Not sure here.)
