Certificate issues on websocket connections
dfkwiki.com
Description of problem:
So I created a fresh Digital Ocean droplet, installed apache2 php certbot etc, SSL working fine certifiate all good when I load any index.php etc you can see the browser is accepting the cert. However for my websocket connections going over port :3000 ie: https://dfkwiki.com:3000/socket.io/?EIO=4&transport=polling&t=Nnuz6sI I suddenly get NET::ERR_CERT_DATE_INVALID despite the expiration date being in the future and the current date being correct. Strangely this is only occurring for some of my users as many are successfully connected to the websocket connection at any time.
In terms of how I'm creating the websockets in node:
const server = https.createServer({
	cert: fs.readFileSync("/etc/letsencrypt/live/dfkwiki.com/cert.pem"),
	key: fs.readFileSync("/etc/letsencrypt/live/dfkwiki.com/privkey.pem"),
}, app);
app.use(cors());
And how I'm connecting client side:
var socket = io.connect("https://dfkwiki.com:3000", {
    secure: true
Strangely this worked for a while on the first server I made and then suddenly stopped and has never gone away. I've had so many people try to help on this and no one can figure it out and its reallyyyy annoying and stopping profress on the site so anything would be amazing.
Thanks in advance.
Sarah
Ubuntu 20.04
PHP 7.4.3
Node v16.11.1
Digital Ocean
Yes
No
certbot 1.20.0
Use your fullchain.pem instead of just the cert.pem. Your client needs the intermediate certificates included in the full chain.
I don't have the words to explain my delight when that graph just loaded. You sir should be knighted.
Thank you SO SO SO SO SO much.
Ha great, glad it worked!
