Certificate issue at its VPS
Good afternoon! I have a client with a blog and would like to translate it to https. We turned to his hosting provider, and he said that he can only issue a paid certificate. We want to transfer the site from shared hosting to a dedicated server. The question is, can we issue a certificate there letsencrypt? Thanks in advance for your reply.
Hi @seminiva
if you have root access, yes, that should work.
Check the list of clients.
But if you have only a standard blog, an own server is a little bit too much. Perhaps it's easier to switch to a hoster with automated Letsencrypt support.
Thank you very much for the answer, apparently I will change the host
