Can't seem to get certbot http test working. My DNS provider is not compatible with the DNS test (Namecheap). I have forwarded all the ports on my router (80, 443), and opened them in my firewall (UFW).
Would appreciate any help.
My domain is: xmpp.burglabs.xyz
sudo certbot certonly --standalone --test-cert
Requesting a certificate for xmpp.burglabs.xyz
Domain: xmpp.burglabs.xyz
Type: connection
Detail: Fetching http://xmpp.burglabs.xyz/.well-known/acme-challenge/-lCOat1jNHNPMqf6LZj32oE5Mpbf8pxuo15hQhJM_X4: Timeout during connect (likely firewall problem)
Prosody V-12
Ubuntu
Ubuntu 21.10
no
or certbot-auto --version
if you're using Certbot): certbot 1.25.0
