Error starting Certbot (Likely firewall problem)
My domain is: pinkhas.hopto.org (DDNS)
I ran this command: certbot -d pinkhas.hopto.org certonly --standalone
Domain: pinkhas.hopto.org
Type: connection
Detail: Fetching http://pinkhas.hopto.org/.well-known/acme-challenge/LVnPZugERvDh4Z03gBfcFnqQnL1AMLHOrDWCjZ3SeJY: Timeout during connect (likely firewall problem)
My web server is (include version): creating one myself, clicked on "Other" in the certbot installation
The operating system my web server runs on is (include version): Win11 (My PC)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.24.0
Soooooo
I've disabled the firewall on my pc (Win11 - the webserver host) and forwarded ports 80 and 443 (Also tried DMZ on/off - same result either way).
When I ran the command with the --manual option, it did create and deleted almost immediately after a .well-known directory contaning a few files.
Any ideas?
Thanks!
Same for me.
Are you sure your IP address is 46.117.123.105 and you have allowed inbound connections on your firewalls (pc, router, isp) and port forwarding on your router?
When I run my web app, I can connect via my external ip as well as the domain name using a browser (port 80 - indicating that my firewalls aren't blocking the connection).
I've also set up a windows firewall "Inbound Rule" and configured a port forwarding rule that leads to my PC to allow all connection using port 80 as TCP.
@pinkhas Welcome to the community
You could add --debug-challenge -v to your command
That will pause before doing the challenge so you (or we) could try it.
The standalone mode is harder to debug otherwise since port 80 is only connected while the standalone server is running.
Ran the command with the suggested args.
As the cmd described, I created a file in C:.well-known\acme-challenge\ with the proper name and value and pressed a key in order to let the program run.
Output:
C:\WINDOWS\system32>certbot -d pinkhas.hopto.org certonly --standalone --debug-challenge -v
Saving debug log to C:\Certbot\log\letsencrypt.log
Requesting a certificate for pinkhas.hopto.org
http-01 challenge for pinkhas.hopto.org
Challenges loaded. Press continue to submit to CA.
The following URLs should be accessible from the internet and return the value
URL:
http://pinkhas.hopto.org/.well-known/acme-challenge/-HyRonz0BP-nCdlCvBbl-AWuyPaJb_YyK2Pncxm5Ka8
Expected value:
-HyRonz0BP-nCdlCvBbl-AWuyPaJb_YyK2Pncxm5Ka8.sy6COMqEWsXkSUoZr-PnXJUvioeTCAQ1DOh0I2vvBDI
Press Enter to Continue
Challenge failed for domain pinkhas.hopto.org
Type: connection
Detail: Fetching http://pinkhas.hopto.org/.well-known/acme-challenge/-HyRonz0BP-nCdlCvBbl-AWuyPaJb_YyK2Pncxm5Ka8: Timeout during connect (likely firewall problem)
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile C:\Certbot\log\letsencrypt.log or re-run Certbot with -v for more details.
You should not create any challenge files certbot does that for you.
Do you have any geo blocking in your firewall?
Try running the command again but when it says "Press Enter to Continue" don't do anything and let us know the URL it is looking for. We can evaluate it better in that condition
Does the Windows firewall allow certbot to listen on port 80 and serve clients? Or just your webapp?
I seem to remember you need to allow each app by itself, on Windows.
Just an observation...
Nmap scan report for pinkhas.hopto.org (46.117.123.105)
Host is up (0.23s latency).
rDNS record for 46.117.123.105: 46-117-123-105.bb.netvision.net.il
PORT    STATE    SERVICE
22/tcp  filtered ssh
53/tcp  filtered domain
80/tcp  filtered http
443/tcp filtered https
defined it as "Any App" - port 80 is open
I'll try to make an outbound rule aswell
Ran, Output:
URL:
http://pinkhas.hopto.org/.well-known/acme-challenge/alzUuQrksKqVp9rkKVe0wpkFod1C1HwSsnpmmHl9aQ0
Expected value:
alzUuQrksKqVp9rkKVe0wpkFod1C1HwSsnpmmHl9aQ0.sy6COMqEWsXkSUoZr-PnXJUvioeTCAQ1DOh0I2vvBDI
Waiting :slight_smile:
That nmap scan is a lot better than the one I did earlier. There was not a single port answering.
Still timeout, @Pinkhas
Great. I can see the correct value using an AWS region in US East Coast (one Let's Encrypt server also in that AWS region).
But, Let's Debug also still cannot see it. It does similar method to Let's Encrypt. Could you have a geo block on Germany or other US areas? Let's Encrypt needs to challenge from several points around the globe (currently usually Germany and up to 3 US sites).
Sure seems like GEO based firewall - maybe in your ISP or router?
Here is my detailed results:
curl -i  http://pinkhas.hopto.org/.well-known/acme-challenge/alzUuQrksKqVp9rkKVe0wpkFod1C1HwSsnpmmHl9aQ0
HTTP/1.0 200 OK
Server: BaseHTTP/0.6 Python/3.9.7
Date: Wed, 02 Mar 2022 20:31:34 GMT
How can I check GEO blocking?
Also, what can I do with your "detailed result"?
You cannot do anything with my 'detailed result'. Just providing more info to other volunteers to confirm what is happening. It just proves the standalone certbot server can be reached from someone.
Check your router for any geographic based firewall (that's what I meant by geo). I think @9peppe is in Italy so he is failing and also Let's Debug and Let's Encrypt which both try from Europe so might be the key pattern.
On it - brb!
Thanks for the tip!
I tried a global reachability website test and it's completely random. Sometimes it works sometimes it doesn't. It doesn't look like it's geographical.
Used @9peppe 's tool, doesn't seem too odd - works with everything but Amsterdam
Should I use a VPN to manipulate geoblocking?
Also, should I terminate the last Certbot request? It is still waiting
@MikeMcQ
It is a bit of a mess, I mean:
No, fine to leave it while debugging it is helpful.
curl to that URL works for me every time from AWS EC2 East Coast. Yet another location at another provider on US East coast times out.
Maybe not geo but could your firewall be blocking requests with certain user-agents?
I don't know the site 9peppe used well enough to evaluate its results. My user-agent was curl from AWS but I will try some others
