Trouble with Certbot Authentication for gomaa.uk: Firewall or Connectivity Issues
gomaa.uk
sudo certbot certonly --standalone -d gomaa.uk -d www.gomaa.uk -d mail.gomaa.uk
Domain: gomaa.uk
Type: connection
Detail: 167.86.73.80: Fetching http://gomaa.uk/.well-known/acme-challenge/ffMGV7wO5WKl7i9HHHlPGhih0N4tS6_26_I745mGecs: Timeout during connect (likely firewall problem)
Domain: mail.gomaa.uk
Type: connection
Detail: 167.86.73.80: Fetching http://mail.gomaa.uk/.well-known/acme-challenge/owTI1u9H7pMB69Vx5yfn0Ew2Y_j7eLpBu20-OU6a23I: Timeout during connect (likely firewall problem)
Domain: www.gomaa.uk
Type: connection
Detail: 167.86.73.80: Fetching http://www.gomaa.uk/.well-known/acme-challenge/gsfwN8Fpq9fVYUR2qLHFO8uDi6TT-_LjGBCnGNa-nhU: Timeout during connect (likely firewall problem)
N/A (I am using Certbot with the standalone authenticator, which doesn't require a web server like Apache or Nginx).
CentOS 8, Linux kernel 4.18.0-553.el8_10.x86_64
(Include the name of your hosting provider, if known)
Yes
No
The version of my client is (e.g., output of certbot --version or certbot-auto --version if you're using Certbot):
(Provide the output of certbot --version, e.g., certbot 2.9.0)
Weird, I'm seeing a webserver responding claiming to be Apache on your hostname.
If I can connect, but Let's Encrypt cannot, most likely some kind of geoblocking is in place.
That can be difficult to debug, especially for Let's Encrypt community volunteers as the Certbot spun up temporary webserver is only up while validation is happening. :frowning:
