Certbot problem timeout
Hi, I want to renew my certs but I have the next problem
Domain: <ejemplo1.mx>
Type: connection
Detail: : Fetching
http://ejemplo1.mx/.well-known/acme-challenge/iOf8rcuhYff9SE8mRGjMDsIDys7dGtEquMT9PpRxVhI:
I already looked for lots of info, I found problem because of ports (80,443), my server is ok, it has listen those ports. I have and external FW and also validated with those ports. I try telnet to verify open ports and it´s ok.
the config nginx isn´t redirecting to another port, it´s just listening in 80.
I tried lots of ways and my problem persist, it was working. I don´t know which problem is.
Can you give me some help please.
thank you.
You need to share your real domain name if you want help.
When you opened this thread in the Help section, you should have been provided with a questionnaire. Maybe you didn't get it somehow (which is weird), or you've decided to delete it. In any case, all the answers to this questionnaire are required:
Do you understand the error message?:
