Certbot - Subdomain Removed From Web Server but Certificate Not Removed From Certbot Management
The problem is as follows. I had have a couple of domains on a server which point to different web roots. I removed a sub domain from the server but certbot keeps trying to renew it. It has now also interfered with the renewal of other domains where the auto renew process just fails.
/opt/certbot-auto renew
Attempting to renew cert from /etc/letsencrypt/renewal/sub.xxx.com-0001.conf produced an unexpected error: Missing command line flag or config entry for this setting:
Select the webroot for chat.xxx.com:
Choices: [‘Enter a new webroot’, ‘/var/www/subxxxdomainroot’]
(You can set this with the --webroot-path flag). Skipping.
The chat.xxx.com doesn’t appear anywhere in any config file that I can find.
nginx version: nginx/1.10.0 (Ubuntu)
ubuntu 16.04.1
AWS
Yes
No
hi @kyluke
Review the syntax for removing a certificate for a given domain
Certbot has it's own way of keeping track of domains and the fact you have removed a server block from your web server is not picked up.
List Known Certificates
Certbot certificates
Delete Certificate
Certbot --delete (name of certificate as above)
Andrei
Thanks Andrei, that is exactly what I am looking for.
I ran ./certbot-auto --delete sub.domain.com but get the following error:
certbot: error: unrecognized arguments: --delete
I’m running certbot version 0.14.2
hi @kyluke
apologies the command is
certbot delete
Andrei
Thanks Andrei. I had to solve it by deleting and re-creating the cert. I also had to manually remove the cert configs in /etc/letsencrypt if anybody is interested.
Thanks for your help.
