Certbot start over
I run my own linux server. certbot 1.32.2
I recently let one of my old domains, learn-to-fly.info, expire. My domains include: cfr.pub , *.ivo-welch.info, learn-to-fly.info . So, now certbot does not want to "renew", with messages like
Renewing an existing certificate for cfr.pub and 23 more domains
  Domain: learn-to-fly.info
  Type:   dns
  Detail: DNS problem: SERVFAIL looking up A for learn-to-fly.info - the domain's nameservers may be malfunctioning; DNS problem: SERVFAIL looking up AAAA for learn-to-fly.info - the domain's nameservers may be malfunctioning
which is of course expected. it also prevents renewal of all the other domains. so, I ran
certbot delete
which tells me only cfr.pub of the first of about 20-25 domains. all the other ones that appear when I just type certbot do not show up. I probably just hosed everything with bad tinkering.
at this point, I am thinking that the smart thing would be to scratch whatever I have, and just start over. is there a list of recommended steps? I presume apt remove certbot would be a terrible idea, because there are still fragments in /etc/certbot, entries in the nginx config directory, etc. It would probably hose the hosed setup even further.
pointers appreciated.
Was that intentional?
By that I mean are you not wanting to keep that domain?
It won't fix whatever damage has been done to the web server configuration.
It will likely make no difference at all.
apt remove certbot
apt install certbot
And you will be exactly where you are now.
You could add this to the renew command for the cert name in question. The risk here is that some other active domain name fails for a transient reason and gets removed from the cert.
That said, this can do what you want
--allow-subset-of-names
When performing domain validation, do not consider it a failure if authorizations can not be obtained for a strict subset of the requested domains. This may be useful for allowing renewals for multiple domains to succeed even if some domains no longer point at this system. This option cannot be used with --csr. (default: False)
From certbot docs
https://eff-certbot.readthedocs.io/en/stable/using.html#certbot-command-line-options
PS: my non-renewal was indeed intentional.
thank you. this solved my main problem, which was to renew all the other domains.
(Removing the /etc/nginx/sites-available/ has also removed the warning now.)
regards,
/iaw
That likely removed all the active [and inactive] web sites on your server.
That's programming... with a chainsaw!
Is there anything left?
sorry, I meant I removed the offending file in /etc/nginx/sites-available, not the full dir, of course.
