Certbot not working after installing pip packages
Problem:
I started having issue with certbot when I installed some pip packages
sudo yum update && sudo yum -y upgrade
sudo yum install python-pip
pip install certbot_dns_route53==0.11.1
My domain is: *.lab.nirmata.co
certbot --version
File "/usr/bin/certbot", line 5, in
from pkg_resources import load_entry_point
File "/usr/lib/python2.7/site-packages/pkg_resources.py", line 3007, in
working_set.require(requires)
File "/usr/lib/python2.7/site-packages/pkg_resources.py", line 728, in require
needed = self.resolve(parse_requirements(requirements))
File "/usr/lib/python2.7/site-packages/pkg_resources.py", line 626, in resolve
raise DistributionNotFound(req)
pkg_resources.DistributionNotFound: requests>=2.6.0
nginx/1.20.1
PRETTY_NAME="CentOS Linux 7 (Core)"
If you want to install Certbot using pip, follow these instructions.
Installing Python packages with pip outside of a Python virtual environment carries a significant risk of breaking your system.
Thanks @_az Issue was resolved after installing the certbot
