I’m using certbot 0.29 with python 2.7 on a centos7.5 and nginx 1.12.2
when i run
certbot --nginx -d domain.example
i got the following error
File “/bin/certbot”, line 5, in
from pkg_resources import load_entry_point
File “/usr/lib/python2.7/site-packages/pkg_resources.py”, line 3011, in
parse_requirements(requires), Environment()
File “/usr/lib/python2.7/site-packages/pkg_resources.py”, line 626, in resolve
raise DistributionNotFound(req)
pkg_resources.DistributionNotFound: acme>=0.29.0
I’m not sure how you got into this situation, but you should be able to repair it.
I managed to get a similarly broken environment by doing:
pip uninstall acme
leading me to your error:
# certbot
File "/usr/bin/certbot", line 5, in <module>
File "/usr/lib/python2.7/site-packages/pkg_resources.py", line 3007, in <module>
working_set.require(__requires__)
File "/usr/lib/python2.7/site-packages/pkg_resources.py", line 728, in require
needed = self.resolve(parse_requirements(requirements))
File "/usr/lib/python2.7/site-packages/pkg_resources.py", line 626, in resolve
and then was able to repair it by re-installing the particular dependency that got messed up:
