Certbot - Installing Issues on Debain 8 - Backports Not Configured
I am looking for at guide on how to setup up Certbot on a server with multible virtual host to manage certificates for two or more of these virtual host. Shell access as root. I get stuck all ready on trying to install certbot… Thanks.
domain1 -> virtual host 1 (need SSL)
domain2 -> virtual host 2 (need SSL)
domain3 -> virtual host 3 (no need for SSL)
domain4 -> virtual host 4 (no need for SSL)
apt-get install python-certbot-apache -t jessie-backports
Reading package lists… Done
E: The value ‘jessie-backports’ is invalid for APT::Default-Release as such a release is not available in the sources
Debian 8.7 - Jessie
Apache version 2.4.10
Our own server
yes, as root
Webmin and there are several virtual hosts administrated by the same webmin. I would like SSL on two of these virtual hosts
hi @tillebeck
The devil is in the details
review: https://certbot.eff.org/#debianjessie-apache
Install
Since Certbot is packaged for your system, all you’ll need to do is apt-get the following packages.
First you’ll have to follow the instructions to enable the Jessie backports repo, if you have not already done so. Then do:
$ sudo apt-get install python-certbot-apache -t jessie-backports
I believe you skipped this step: https://backports.debian.org/Instructions/ which is why your debian system can’t find the repo and hence why the APT command doesn’t work :smiley:
Andrei
Thank you. It is installing right now. I did not see that the “here” was a link and not just referring to apt-get line just below. Thanks for pointing that out. I will continue with the guide :slight_smile:
@tillebeck
it’s all good
that’s why i started with The devil is in the details
i have been guilty of the same things and it’s always good to get a second pair of eyes to look over it :smiley:
andrei
