agozie
September 25, 2019, 6:44am
1
Please, I'm new to hosting, so would like for simple explanations. I'm trying to get an HTTPS certificate for my website, but I'm getting errors installing the certificate. After putting my domain, it keeps telling me certificate not installed.
My domain is: www.fiftonacademy.com
sudo certbot --nginx
- Unable to install the certificate
/etc/letsencrypt/live/www.fiftonacademy.com/fullchain.pem
/etc/letsencrypt/live/www.fiftonacademy.com/privkey.pem
Your cert will expire on 2019-12-23. To obtain a new or tweaked
with the "certonly" option. To non-interactively renew *all* of
nginx/1.14.0 (Ubuntu)
Ubuntu 18.04
Digital Ocean
Yes
No
certbot 0.31.0
Please any help is appreciated.
Hi @agozie
there is a check of your domain, ~~ one hour old - https://check-your-website.server-daten.de/?q=fiftonacademy.com
Issuer
not before
not after
Domain names
LE-Duplicate
next LE
Let's Encrypt Authority X3
2019-09-24
2019-12-23
www.fiftonacademy.com - 1 entries
duplicate nr. 1
One certificate is created.
Looks like Certbot doesn't understand your configuration.
What says
nginx -T
agozie
September 25, 2019, 6:51pm
3
@JuergenAuer Below is the the return from nginx -T
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip.conf:
load_module modules/ngx_http_geoip_module.so;
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/svg+xml svg svgz;
image/webp webp;
application/font-woff woff;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.wap.wmlc wmlc;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
application/vnd.openxmlformats-officedocument.wordprocessingml.document docx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/sites-enabled/default:
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
listen 80;
server_name 134.209.21.86:8000;
root /var/www/html;
proxy_pass http://134.209.21.86:8000;
proxy_set_header Host $http_host;
proxy_set_header X-NginX-Proxy true;
location /static/admin {
alias /root/Fifton/fiftonacad-master/staticfiles/admin;
location /static/ {
alias /root/Fifton/fiftonacad-master/staticfiles/;
location /media/ {
autoindex on;
alias /path/to/media/;
schoen
September 25, 2019, 7:03pm
4
Certbot expects you to have an existing server block using HTTP that refers to the name, not the IP address, of your server, so that it can use this as a basis for creating a matching HTTPS server block.
There is no server_name defined.
Something like
server_name www.fiftonacademy.com;
is expected.
system
Closed
October 25, 2019, 11:09pm
7
