Installed certificate, but https site not working
My domain is: www.childrenscodingclub.com
I ran this command:sudo certbot --nginx
Requesting a certificate for childrenscodingclub.com and www.childrenscodingclub.com
Certificate is saved at: /etc/letsencrypt/live/childrenscodingclub.com/fullchain.pem
Key is saved at: /etc/letsencrypt/live/childrenscodingclub.com/privkey.pem
This certificate expires on 2022-04-09.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
Deploying certificate
Successfully deployed certificate for childrenscodingclub.com to /etc/nginx/sites-enabled/childrenscodingclub.com
Successfully deployed certificate for www.childrenscodingclub.com to /etc/nginx/sites-enabled/childrenscodingclub.com
Congratulations! You have successfully enabled HTTPS on https://childrenscodingclub.com and https://www.childrenscodingclub.com
My web server is (include version): nginx version: nginx/1.18.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 20.04.1 LTS
My hosting provider, if applicable, is: AWS EC2 instance
no, using ssh
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 1.22.0
All looks good. Check your AWS Security Group to ensure you allow traffic for port 443
Thanks! This solved it, and I can see the site at https://childrenscodingclub.com
Newbie to implementing https, so looks like I now have to change requests going from my Angular application to https, and unsure yet if socket.io requests served through my node server will continue to work or not. Will do some research and make headway.
