Certbot failed to authenticate some domains (authenticator: webroot) : Connection refused
My domain is: makaveli.kiosquelitteraire.org
docker run --rm \
  -v /var/www/greencheck/backend/certbot/www:/var/www/certbot \
  -v /var/www/greencheck/backend/certbot/conf:/etc/letsencrypt \
  certbot/certbot certonly \
  --webroot \
  --webroot-path=/var/www/certbot \
  --email nzanzu.lwanzo.work@gmail.com \
  --agree-tos \
  --no-eff-email \
  -d makaveli.kiosquelitteraire.org \
  -d www.makaveli.kiosquelitteraire.org
  Domain: makaveli.kiosquelitteraire.org
  Type:   connection
  Detail: 157.180.69.108: Fetching http://makaveli.kiosquelitteraire.org/.well-known/acme-challenge/TCeIbthT_uJvaSB6cBdqjxwLOk66hv9et3gSfArdYBY: Connection refused
  Domain: www.makaveli.kiosquelitteraire.org
  Type:   connection
  Detail: 157.180.69.108: Fetching http://www.makaveli.kiosquelitteraire.org/.well-known/acme-challenge/6lMjy6PSN7TVjSuB9UCr2oZEvPTkdJI3-vaIO3K4koM: Connection refused
My web server is (include version): Hetzner
The operating system my web server runs on is (include version): Ubuntu 24
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): Using Certbot from Docker (latest)
Your system is refusing HTTP (port 80) requests coming from the public internet.
You didn't describe what web server you were using (Apache, nginx, other?) but usually that is what would reply to those requests.
This isn't unique to Let's Encrypt. A check from many places world-wide are all refused. Check firewalls, network configuration, and any port routing to/from your container.
