My domain is: test1.mrvanes.com
certbot certonly --standalone --non-interactive --agree-tos --email letsencrypt@mrvanes.com --http-01-port=8888 -d test1.mrvanes.com
It produced this output (with CNAME for test1.mrvanes.com):
saving debug log to /var/log/letsencrypt/letsencrypt.log
Requesting a certificate for test1.mrvanes.com
http-01 challenge for test1.mrvanes.com
Challenge failed for domain test1.mrvanes.com
Domain: test1.mrvanes.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for test1.mrvanes.com -
check that a DNS record exists for this domain; no valid AAAA
records found for test1.mrvanes.com
It produced this output (with A record for test1.mrvanes.com):
/etc/letsencrypt/live/test1.mrvanes.com/fullchain.pem
/etc/letsencrypt/live/test1.mrvanes.com/privkey.pem
Your certificate will expire on 2022-10-11. To obtain a new or
tweaked version of this certificate in the future, simply run
certbot again. To non-interactively renew *all* of your
certificates, run "certbot renew"
It's important to note that the command succeeds with CNAME when running wit --dry-run:
Simulating a certificate request for test1.mrvanes.com
- The dry run was successful
My web server is (include version): haproxy (2.2.9) + certbot --standalone
Following this is a haproxy howto:
The operating system my web server runs on is (include version): Ubuntu 21.04
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.12.0
