Problem with Hostinger Domain and Certbot
premiosstumbleguys.com
sudo certbot certonly --standalone
root@localhost:/# sudo certbot certonly --standalone
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): premiosstumbleguys.info
Requesting a certificate for premiosstumbleguys.info
Domain: premiosstumbleguys.info
Detail: 2600:1901:0:84ef::: Invalid response from http://premiosstumbleguys.info/.well-known/acme-challenge/fO1g-j7W2OR9DlDGAFdtHpvG5lfM52cV5KFeoVp7Bqo: 404
Hostinger domain
Ubuntu 20.04
Ionos
no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.4.0
In hostinger I have A reocord with @ and pointing to the IP of the Server with TTL 14400
It's not clear to me whether your DNS is set up right, but if you want to use --standalone, you'd need to stop your openresty web server first.
You say your domain is ...com
Then show an invalid response from ...info
Which is it?
The .com has no DNS record.
The .info doesn't resolve to the IPv6 shown in the error message.
And has a working web service:
HTTP/1.1 404 Not Found
X-Powered-By: Express
Content-Security-Policy: default-src 'none'
X-Content-Type-Options: nosniff
Content-Type: text/html; charset=utf-8
Content-Length: 210
Date: Wed, 05 Apr 2023 00:03:58 GMT
Keep-Alive: timeout=5
None of which adds up - with my calculator.
