Upgrading certbot-auto 0.36.0 to 0.40.0…
Couldn’t download https://raw.githubusercontent.com/certbot/certbot/v0.40.0/letsencrypt-auto-source/letsencrypt-auto.
Hi @voidlh,
How recently did you try this?
Is access to https://raw.githubusercontent.com/ blocked from your network?
A random unrelated-to-Certbot file that you could try to access
https://raw.githubusercontent.com/Homebrew/install/master/install
for example, you could try with
curl -v https://raw.githubusercontent.com/Homebrew/install/master/install
on your web server to see if it can access that.
curl-v https://raw.githubusercontent.com/Homebrew/install/master/install
-bash: curl-v: command not found
[root@VM_0_2_centos ~]# curl -v https://raw.githubusercontent.com/Homebrew/install/master/install
- About to connect() to raw.githubusercontent.com port 443 (#0)
- Trying 199.16.156.40...
- Connection timed out
- Failed connect to raw.githubusercontent.com:443; Connection timed out
- Closing connection 0
curl: (7) Failed connect to raw.githubusercontent.com:443; Connection timed out
我是在腾讯云服务器上布署的。
我在阿里云上偿试了一下连接发现是可以的。
curl -v https://raw.githubusercontent.com/Homebrew/install/master/install - About to connect() to raw.githubusercontent.com port 443 (#0)
- Trying 151.101.108.133...
- Connected to raw.githubusercontent.com (151.101.108.133) port 443 (#0)
- Initializing NSS with certpath: sql:/etc/pki/nssdb
- CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none - SSL connection using TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
- Server certificate:
subject: CN=www.github.com,O="GitHub, Inc.",L=San Francisco,ST=California,C=US
start date: Mar 23 00:00:00 2017 GMT
expire date: May 13 12:00:00 2020 GMT
common name: www.github.com
issuer: CN=DigiCert SHA2 High Assurance Server CA,OU=www.digicert.com,O=DigiCert Inc,C=US
GET /Homebrew/install/master/install HTTP/1.1
User-Agent: curl/7.29.0
Host: raw.githubusercontent.com
Accept: /
< HTTP/1.1 200 OK
< Content-Type: text/plain; charset=utf-8
< Content-Security-Policy: default-src 'none
it looks like raw.githubusercontent.com is blocked by GFW. which file you need?
Just tested... and seems like GitHub is fine on both service provider.
你试一下清空DNS缓存然后再试一下?
我阿里云和腾讯云机子都没有问题...
