Joo
1
I have an issue with renew of my certificate.
I ran this command as root:
./letsencrypt-auto renew
Upgrading certbot-auto 0.28.0 to 0.30.0...
Couldn't download https://raw.githubusercontent.com/certbot/certbot/v0.30.0/letsencrypt-auto-source/letsencrypt-auto. <urlopen error timed out>
My operating system:
Debian GNU/Linux 8.11 (jessie)
The renew three months ago ran smoothly. Unfortunately not today.
Maybe someone can guide me to solve the issue.
Thank you!
Hi @Joo
are you able to connect other websites from this server?
curl www.google.com
Joo
3
Hi Juergen,
Yes, I am able to connect to other websites... also to google.
curl www.google.com
<!doctype html><meta content="text/html; ch
(sorry, I am not able to past the result here, too many > and < [angle brackets] )
Perhaps one of the name servers has an expired ip cached.
Check
nslookup raw.githubusercontent.com
or
dig raw.githubusercontent.com
to see the current ip address of raw.githubusercontent.com
. If this doesn’t work, check your /etc/hosts
file and add
151.101.112.133 raw.githubusercontent.com
as a static (temporary) ip address.
Joo
5
@JuergenAuer
Thank you very much, I was abel to solfing the issue and renew certificates now.
The issue was an entry in my iptables. It blocked one of the IP of *.fastly.net
system
Closed
6
