My domain is: si.diese.org, relecture.diese.org, wiki.diese.org
I ran this command: certbot-auto renew
Ign http://security.debian.org wheezy/updates/main Translation-en_US
Err http://security.debian.org wheezy/updates/main Sources
404 Not Found [IP: 151.101.120.204 80]
Err http://security.debian.org wheezy/updates/main amd64 Packages
Ign http://http.debian.net wheezy-backports/main Translation-en_US
Err http://http.debian.net wheezy-backports/main amd64 Packages
W: Failed to fetch http://ftp.debian.org/debian/dists/jessie-backports/main/binary-amd64/Packages 404 Not Found [IP: 130.89.148.12 80]
W: Failed to fetch http://ftp.fr.debian.org/debian/dists/wheezy/main/source/Sources 404 Not Found [IP: 212.27.32.66 80]
W: Failed to fetch http://ftp.fr.debian.org/debian/dists/wheezy/main/binary-amd64/Packages 404 Not Found [IP: 212.27.32.66 80]
W: Failed to fetch http://ftp.fr.debian.org/debian/dists/wheezy-updates/main/source/Sources 404 Not Found [IP: 212.27.32.66 80]
W: Failed to fetch http://ftp.fr.debian.org/debian/dists/wheezy-updates/main/binary-amd64/Packages 404 Not Found [IP: 212.27.32.66 80]
W: Failed to fetch http://security.debian.org/dists/wheezy/updates/main/source/Sources 404 Not Found [IP: 151.101.120.204 80]
W: Failed to fetch http://security.debian.org/dists/wheezy/updates/main/binary-amd64/Packages 404 Not Found [IP: 151.101.120.204 80]
W: Failed to fetch http://http.debian.net/debian/dists/wheezy-backports/main/binary-amd64/Packages 404 Not Found [IP: 151.101.120.204 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
apt-get update hit problems but continuing anyway…
Reading package lists… Done
Building dependency tree
Reading state information… Done
gcc is already the newest version.
python is already the newest version.
python-dev is already the newest version.
python-virtualenv is already the newest version.
libffi-dev is already the newest version.
libssl-dev is already the newest version.
openssl is already the newest version.
libaugeas0 is already the newest version.
augeas-lenses is already the newest version.
ca-certificates is already the newest version.
The following packages were automatically installed and are no longer required:
iso-codes liblinear-tools liblinear1 python3 python3-minimal python3.2 python3.2-minimal
Use ‘apt-get autoremove’ to remove them.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Creating virtual environment…
Installing Python packages…
/opt/eff.org/certbot/venv/bin/python: No module named pip.main; ‘pip’ is a package and cannot be directly executed
File “/tmp/tmp.zoHL37cWOP/pipstrap.py”, line 177, in
sys.exit(main())
File “/tmp/tmp.zoHL37cWOP/pipstrap.py”, line 149, in main
pip_version = StrictVersion(check_output([python, ‘-m’, ‘pip’, ‘–version’])
File “/usr/lib/python2.7/subprocess.py”, line 544, in check_output
raise CalledProcessError(retcode, cmd, output=output)
subprocess.CalledProcessError: Command ‘[’/opt/eff.org/certbot/venv/bin/python’, ‘-m’, ‘pip’, ‘–version’]’ returned non-zero exit status 1
My web server is (include version): Apache/2.2.22
The operating system my web server runs on is (include version): Debian 8.7
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): Can’t get it
