Cant renew. certbot-auto not working on Debian Wheezy. Please help
My domain is: Oleg
I ran this command: ./certbot-auto
Creating virtual environment…
File “/usr/lib/python2.7/dist-packages/virtualenv.py”, line 2283, in
main()
File “/usr/lib/python2.7/dist-packages/virtualenv.py”, line 938, in main
never_download=options.never_download)
File “/usr/lib/python2.7/dist-packages/virtualenv.py”, line 1054, in create_environment
install_pip(py_executable, search_dirs=search_dirs, never_download=never_download)
File “/usr/lib/python2.7/dist-packages/virtualenv.py”, line 643, in install_pip
filter_stdout=_filter_setup)
File “/usr/lib/python2.7/dist-packages/virtualenv.py”, line 976, in call_subprocess
cwd=cwd, env=env)
File “/usr/lib/python2.7/subprocess.py”, line 710, in init
errread, errwrite)
File “/usr/lib/python2.7/subprocess.py”, line 1335, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
My web server is (include version): nginx (+Apache2)
The operating system my web server runs on is (include version): Debian 7 (Wheezy)
My hosting provider, if applicable, is: Own Server
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): i’down know. this command doesnt work with the same error
Hi @Spol
looks like you have a very old certbot-auto.
So install certbot-auto new:
Some additional information:
#lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 7.11 (wheezy)
Release: 7.11
Codename: wheezy
./certbot-auto renew --verbose
Bootstrapping dependencies for Debian-based OSes… (you can skip this with --no-bootstrap)
В кэше http://mirror.yandex.ru wheezy Release.gpg
В кэше http://mirror.yandex.ru wheezy-updates Release.gpg
В кэше http://mirror.yandex.ru wheezy/main Sources
В кэше http://mirror.yandex.ru wheezy/main amd64 Packages
В кэше http://mirror.yandex.ru wheezy/main Translation-ru
В кэше http://mirror.yandex.ru wheezy/main Translation-en
В кэше http://mirror.yandex.ru wheezy-updates/main Sources
В кэше http://mirror.yandex.ru wheezy-updates/main amd64 Packages/DiffIndex
В кэше http://mirror.yandex.ru wheezy-updates/main Translation-en/DiffIndex
В кэше http://security.debian.org wheezy/updates Release.gpg
В кэше http://http.debian.net wheezy-backports Release.gpg
В кэше http://security.debian.org wheezy/updates/main Sources
В кэше http://security.debian.org wheezy/updates/main amd64 Packages
В кэше http://security.debian.org wheezy/updates/main Translation-en
В кэше http://http.debian.net wheezy-backports/main amd64 Packages/DiffIndex
В кэше http://http.debian.net wheezy-backports/main Translation-en/DiffIndex
Чтение списков пакетов… Готово
Построение дерева зависимостей
Чтение информации о состоянии… Готово
Уже установлена самая новая версия gcc.
Уже установлена самая новая версия python.
Уже установлена самая новая версия python-dev.
Уже установлена самая новая версия python-virtualenv.
Уже установлена самая новая версия ca-certificates.
Уже установлена самая новая версия libffi-dev.
Уже установлена самая новая версия libssl-dev.
Уже установлена самая новая версия openssl.
Уже установлена самая новая версия augeas-lenses.
Уже установлена самая новая версия libaugeas0.
обновлено 0, установлено 0 новых пакетов, для удаления отмечено 0 пакетов, и 7 пакетов не обновлено.
Running virtualenv with interpreter /usr/bin/python2.7
The --no-site-packages flag is deprecated; it is now the default behavior.
New python executable in /opt/eff.org/certbot/venv/bin/python2.7
Also creating executable in /opt/eff.org/certbot/venv/bin/python
Installing distribute…done.
Installing pip…
Error [Errno 2] No such file or directory while executing command /opt/eff.org/certbot/venv/bin/easy_install /usr/share/python-vi…p-1.1.debian1.tar.gz
…Installing pip…done.
main()
cwd=cwd, env=env)
errread, errwrite)
l# head -n1 $(which lsb_release)
#! /usr/bin/python
$(command -v python2.7 || command -v python27 || command -v python2 || command -v python) --version
Python 2.7.9
virtualenv --no-site-packages --python $(command -v python2.7 || command -v python27 || command -v python2 || command -v python) tmp_venv
New python executable in tmp_venv/bin/python2.7
Also creating executable in tmp_venv/bin/python
Installing pip…
Error [Errno 2] No such file or directory while executing command /home/spol/tmp_venv/bin/easy_install /usr/share/python-vi…p-1.1.debian1.tar.gz
main()
cwd=cwd, env=env)
errread, errwrite)
root@breeze:/home/spol# . ./tmp_venv/bin/activate
bash: ./tmp_venv/bin/activate: Нет такого файла или каталога (No such file or catalog)
root@breeze:/home/spol# lsb_release -a
Release: 7.11
Codename: wheezy
The same error
wget https://dl.eff.org/certbot-auto
–2019-03-07 11:10:33-- https://dl.eff.org/certbot-auto
root@breeze:/home/spol/_new_certbot# chmod 755 certbot-auto
root@breeze:/home/spol/_new_certbot# ./certbot-auto renew
Upgrading certbot-auto 0.31.0 to 0.32.0…
Replacing certbot-auto…
main()
cwd=cwd, env=env)
errread, errwrite)
Upgrading certbot-auto 0.31.0 to 0.32.0… Replacing certbot-auto…
main()
cwd=cwd, env=env)
errread, errwrite)
tha same error with new certbot-auto
additional info:
#lsb_release -a
Release: 7.11
Codename: wheezy
Python 2.7.9
#! /usr/bin/python
certbot-auto is currently not working on Debian Wheezy.
One workaround is to run 0.31 with --no-self-upgrade, as suggested on the issue.
When I tried to generate a certificate for a new domain certbot-auto started to upgrade from 0.30.2 to 0.32.0 but failed with this output:
Upgrading certbot-auto 0.30.2 to 0.32.0...
Replacing certbot-auto...
Creating virtual environment...
Installing Python packages...
/opt/eff.org/certbot/venv/bin/python: No module named pip.__main__; 'pip' is a package and cannot be directly executed
  File "/tmp/tmp.PScBmyRocA/pipstrap.py", line 177, in <module>
    sys.exit(main())
  File "/tmp/tmp.PScBmyRocA/pipstrap.py", line 149, in main
    pip_version = StrictVersion(check_output([python, '-m', 'pip', '--version'])
  File "/usr/lib/python2.7/subprocess.py", line 544, in check_output
    raise CalledProcessError(retcode, cmd, output=output)
subprocess.CalledProcessError: Command '['/opt/eff.org/certbot/venv/bin/python', '-m', 'pip', '--version']' returned non-zero exit status 1
Trying to run any certbot-auto command results in it wanting to upgrade and fails. Using the --no-self-upgrade option results in failing to create a virtual environment (I assume because of the failed upgrade?):
  File "/usr/bin/virtualenv", line 3, in <module>
    virtualenv.main()
  File "/usr/lib/python2.7/dist-packages/virtualenv.py", line 880, in main
    interpreter = resolve_interpreter(options.python)
  File "/usr/lib/python2.7/dist-packages/virtualenv.py", line 1536, in resolve_interpreter
    if os.path.abspath(exe) != exe:
  File "/usr/lib/python2.7/posixpath.py", line 347, in abspath
    cwd = os.getcwd()
OS: ubuntu 12.04.5
python: 2.7.3-0ubuntu2.2
python-pip: 1.0-1build1
I know the server is old and needs to be migrated in the near future, but for now can anyone tell me how could I fix this problem so I can generate the certificate?
Hi @Emi94, I’ve moved your post into this thread, which is the identical issue.
Your OS is very old and is unsupported by Certbot.
You can try the workaround posted in the Github issue.
This works for me:
ln -fs /usr/lib/python2.7/plat-x86_64-linux-gnu/_sysconfigdata_nd.py /usr/lib/python2.7/
wget https://raw.githubusercontent.com/certbot/certbot/75499277be6699fd5a9b884837546391950a3ec9/certbot-auto
chmod +x ./certbot-auto
certbot-auto renew --no-self-upgrade
it download some files and work fine.
Installing certbot-auto 0.31.0 as suggested in the github issue solved the problem.
Thanks.
Debian Wheezy is so old that it’s not worth wasting any time on. Instead of spending time and effort on getting something to work with a completely obsolete version of Debian, just upgrade to the current stable release.
It’s kind of pointless trying to get https working on a system that is so old it no longer gets security updates. Debian stopped official support for security updates on Wheezy in the middle of 2018: https://www.debian.org/News/2018/20180601
