Cert was not autorenewd
My domain is: cloud.fr0scher.de
I ran this command: letsencrypt certonly -a webroot --webroot-path=/var/www/letsencrypt --rsa-key-size 4096 -d cloud.fr0scher.de
It produced this output:Saving debug log to /var/log/letsencrypt/letsencrypt.log
http-01 challenge for cloud.fr0scher.de
Using the webroot path /var/www/letsencrypt for all unmatched domains.
Waiting for verification…
Unable to clean up challenge directory /var/www/letsencrypt/.well-known/acme-challenge
Failed authorization procedure. cloud.fr0scher.de (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://cloud.fr0scher.de/.well-known/acme-challenge/wrsu_zln1471AW9ur2EzVELyOaQD_NthbwDCVqMrZ0g: Error getting validation data
    Domain: cloud.fr0scher.de
    Type: connection
    Detail: Fetching
My web server is (include version): nginx/1.15.3
The operating system my web server runs on is (include version): Debian 9
I have a server at home and use an account at no-ip.org to publish it to the internet with portforwarding in my fritz box. cloud.fr0scher.de is just a cname at my provider.
Hi @timmekk
your http port 80 doesn't answer ( https://check-your-website.server-daten.de/?q=cloud.fr0scher.de ):
83.135.125.224 -14 10.033 T
Timeout - The operation has timed out
https://cloud.fr0scher.de/
83.135.125.224 302 Login – Nextcloud 5.820 N
Certificate error: RemoteCertificateNameMismatch, RemoteCertificateChainErrors
Login – Nextcloud 200 1.344 N
http://cloud.fr0scher.de/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
83.135.125.224 -14 10.027 T
You must have a running port 80. Your certificate
CN=cloud.fritz.box
18.09.2018
15.09.2028
cloud.fritz.box - 1 entry
is a self signed fritz.box. Do you have a port forwarding port 80 -> your webserver instance?
oh okay. I have now forwarded the port 80 to our server. but does not work.
It's the same problem, timeout. Querying
83.135.125.224
-14 10.026 T Timeout - The operation has timed out
there is a http status 404 required, so your server must answer.
This doesn't seem like a REAL webroot.
The Webroot must match the Document Root folder.
