Hi, inexperienced with this (but learning:roll_eyes:). We have lost connectivity to out web site/s, due it seems to a certificate not auto renewing. I note the lines in the output of certbot in terminal about firewall but no changes have been made by me/us here. Obviously something has changed, port 443 is pointing to .50. I need help on where to start looking to fix/remove the issue creating the certbot output. Please could someone direct me any which way… log files? config files to check etc… Thanks in advance…
Joe.
My domain is: bodekerscientific.com
I ran this command: sudo certbot --nginx
1: confluence.bodekerscientific.com
2: jira.bodekerscientific.com
3: jira-webapps.bodekerscientific.com
4: rdc.bodekerscientific.com
5: svn.bodekerscientific.com
blank to select all options shown (Enter ‘c’ to cancel):
requested (ref: /etc/letsencrypt/renewal/confluence.bodekerscientific.com.conf)
It contains these names: confluence.bodekerscientific.com
You requested these names for the new certificate:
confluence.bodekerscientific.com, jira.bodekerscientific.com,
jira-webapps.bodekerscientific.com, rdc.bodekerscientific.com,
svn.bodekerscientific.com.
certificate?
(E)xpand/©ancel: E
http-01 challenge for confluence.bodekerscientific.com
http-01 challenge for jira-webapps.bodekerscientific.com
http-01 challenge for jira.bodekerscientific.com
http-01 challenge for rdc.bodekerscientific.com
http-01 challenge for svn.bodekerscientific.com
Waiting for verification…
Failed authorization procedure. rdc.bodekerscientific.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://rdc.bodekerscientific.com/.well-known/acme-challenge/T9H4ZFNzQCwut9pCIyMTrk5f7LEu7KxEdL7kRC7qCBw: Timeout during connect (likely firewall problem), confluence.bodekerscientific.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://confluence.bodekerscientific.com/.well-known/acme-challenge/tikrmlVANiKdI6rq3Zm4j9Np63pqtkQHhdQxtm4jV_Y: Timeout during connect (likely firewall problem), jira-webapps.bodekerscientific.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://jira-webapps.bodekerscientific.com/.well-known/acme-challenge/uff9w6Jt-apP_tYHJC9R0BGZDAqLjKugf25jUuXdx50: Timeout during connect (likely firewall problem), jira.bodekerscientific.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://jira.bodekerscientific.com/.well-known/acme-challenge/egg_XOxMcbbaYYu5lhjtr7DrsF3rzwkr0og2cL56OB8: Timeout during connect (likely firewall problem), svn.bodekerscientific.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://svn.bodekerscientific.com/.well-known/acme-challenge/VUEiw33QVyafJ_6ZW9RXRlv54ukEG5OaoczFADmiwZI: Timeout during connect (likely firewall problem)
My web server is (include version): not sure
On the machine throwing the certbot output: nginx version: nginx/1.10.3 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu svr 16 lts
My hosting provider, if applicable, is: eNom
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): noe
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
