Cert expired and I'm having trouble renewing
My domain is: www.krainbuild.com
sudo mv /opt/bitnami/apache2/conf/cert.csr/opt/bitnami/apache2/conf/cert.csr.old
mv: cannot stat ‘/opt/bitnami/apache2/conf/server.csr’: No such file or directory
Bitnami?
AWS
no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot: command not found
Hi @angi
checking your domain there is a certificate - 33 days expired - https://check-your-website.server-daten.de/?q=krainbuild.com#certificates
CN=www.krainbuild.com
	15.07.2019
	13.10.2019
33 days expired	krainbuild.com, www.krainbuild.com - 2 entries
And there is a new certificate, created today.
Let's Encrypt Authority X3 2019-11-15 2020-02-13 krainbuild.com, www.krainbuild.com
2 entries duplicate nr. 1
Let's Encrypt Authority X3 2019-07-15 2019-10-13 krainbuild.com, www.krainbuild.com
2 entries
Let's Encrypt Authority X3 2019-04-04 2019-07-03 krainbuild.com, www.krainbuild.com
2 entries
2 entries
Let's Encrypt Authority X3 2018-11-29 2019-02-27 krainbuild.com, www.krainbuild.com
2 entries
Let's Encrypt Authority X3 2018-11-28 2019-02-26 krainbuild.com, www.krainbuild.com
2 entries
Let's Encrypt Authority X3 2018-11-26 2019-02-24 krainbuild.com, www.krainbuild.com
2 entries
Let's Encrypt Authority X3 2018-11-19 2019-02-17 krainbuild.com, www.krainbuild.com
2 entries
Bitnami requires additional steps to use a certificate.
So do these steps again.
Hi! Thanks for the reply. In my attempts to try to use this new cert, I used these commands:
sudo mv /opt/bitnami/apache2/conf/krainbuild.com.crt /opt/bitnami/apache2/conf/krainbuild.com.crt.old
sudo mv /opt/bitnami/apache2/conf/krainbuild.com.key /opt/bitnami/apache2/conf/krainbuild.com.key.old
sudo mv /opt/bitnami/apache2/conf/cert.csr /opt/bitnami/apache2/conf/cert.csr.old
sudo ln -sf /opt/bitnami/letsencrypt/certificates/krainbuild.com.key /opt/bitnami/apache2/conf/krainbuild.com.key
sudo ln -sf /opt/bitnami/letsencrypt/certificates/krainbuild.com.crt /opt/bitnami/apache2/conf/krainbuild.com.crt
sudo chown root:root /opt/bitnami/apache2/conf/server*
sudo chmod 600 /opt/bitnami/apache2/conf/server*
The one I bolded gives me the error I posted above. I’m guessing that’s a Bitnami problem then?
Thanks again!
No. The mv is the shell command move MV - Wikipedia - that has nothing to do with Bitnami.
Perhaps a typo. And you can't move the same file two times.
And your error message doesn't look like a problem with your command - your command doesn't use server.csr.
Hmm…I’m using the instructions on this page:
https://docs.bitnami.com/aws/how-to/generate-install-lets-encrypt-ssl/
(I changed domain to my domain. Then I found a support article that said to replace server too, so I tried that too).
Do you have any suggestions on how I can install the new certificate? Thanks!
If you are mixing different sources, how should that work?
