Entered the command: certbot-auto renew Server DNS is correct
Receive the following:
http-01 challenge for cnow9..com
Waiting for verification…
Attempting to renew cert (cnow9..com) from /etc/letsencrypt/renewal/cnow9..com.conf produced an unexpected error: Failed authorization procedure. cnow9..com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://cnow9..com/.well-known/acme-challenge/KwJ3aDbhy0pcgBJV7bcO0Xue6KbVt19DM4kI8SLISSQ: "
/etc/letsencrypt/live/cnow9..com/fullchain.pem (failure)
Domain: cnow9..com
Detail: Invalid response from http://cnow9..com/.well-known/acme-challenge/KwJ3aDbhy0pcgBJV7bcO0Xue6KbVt19DM4kI8SLISSQ:
Oritor
<meta property="og:title" content="Or"
You have probably some address rewrite rules, which are redirecting all requests to your app and it makes it impossible for Let’s Encrypt validation servers to access verification file. You have to make sure that all URLs beginning with /.well-known/acme-challenge/ are handled by webserver itself.
@rg305: I think the part of the domain between these two dots was removed - which is kinda pointless, as I was able to find full domain name using Certificate Transparency logs…
certbot-auto certonly --webroot-path /var/www/html
Failed to find executable apache2ctl in PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
1: Spin up a temporary webserver (standalone)
2: Place files in webroot directory (webroot)
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 2
Please enter in your domain name(s) (comma and/or space separated) (Enter 'c’
to cancel): cnow9.oritor.com
http-01 challenge for cnow9.oritor.com
Using the webroot path /var/www/html for all unmatched domains.
Failed authorization procedure. cnow9.oritor.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://cnow9.oritor.com/.well-known/acme-challenge/gtzkkipdQUab_uKPSspyekeds01qU5hJQsZeoIbGh9U: "
You need to be sure that a request to http://cnow9.oritor.com/.well-known/acme-challenge/whatever is going to read the files on your web root, in your case /var/www/html/.well-known/acme-challenge/whatever
so before trying to issue a cert check it yourself.
1.- Create a test file
mkdir -p /var/www/html/.well-known/acme-challenge/
echo "this is a challenge test" > /var/www/html/.well-known/acme-challenge/test
2.- Check that you can view the file using your browser.
If you can’t view the text “this is a challenge test” then or you are not specifying the right web root for your domain (keep in mind that you are redirecting http to https and maybe you have different web roots /var/www/html/ for request to port 80 and another path for requests to port 443) or as other mates said, maybe you have some rewrite rule doing something strange.
