Problem with renewing certificates
My domain is: partcatalog.ru
./letsencrypt-auto renew
Processing /etc/letsencrypt/renewal/partcatalog.ru.conf
http-01 challenge for partcatalog.ru
Attempting to renew cert (partcatalog.ru) from /etc/letsencrypt/renewal/partcatalog.ru.conf produced an unexpected error: Failed authorization procedure. partcatalog.ru (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://partcatalog.ru/.well-known/acme-challenge/IlAXbhDd3Su72SFWzXJy9j96-8sGW1pvUIcS5GFkUus: "\n\n404 Not Found\n\n
Not Found
\n<p". Skipping.
Apache
Debian 7
I can login to a root shell on my machine:
Yes
I'm using a control panel to manage my site:
No
I understand that an error occurs when confirming domain rights.
I created folders at: /var/www/partcatalog.ru/.well-known/acme-challenge
Exposed permission level 755
What text should I place and where can the system check my domain? Or do you need to add some information in DNS?
Hi @oleg_antonov
I see, you have already checked your domain via partcatalog.ru - Make your website better - DNS, redirects, mixed content, certificates :
There is one problem:
• http://partcatalog.ru/
5.44.103.11 302 https://partcatalog.ru/ 0.047 A
• http://www.partcatalog.ru/
5.44.103.11 302 https://www.partcatalog.ru/ 0.047 A
• https://partcatalog.ru/
5.44.103.11 200 1.423 N
Certificate error: RemoteCertificateChainErrors
• https://www.partcatalog.ru/
5.44.103.11 200 1.360 N
Certificate error: RemoteCertificateNameMismatch, RemoteCertificateChainErrors
• http://partcatalog.ru/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
5.44.103.11 302 https://partcatalog.ru/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.064 A
• http://www.partcatalog.ru/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
5.44.103.11 302 https://www.partcatalog.ru/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.043 A
• https://partcatalog.ru/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 200 1.267 N
• https://www.partcatalog.ru/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 200 1.266 N
The redirect http -> https is ok, Letsencrypt ignores the wrong certificate. But checking a not existing file
https://www.partcatalog.ru/.well-known/acme-challenge/1234
your server sends a http status 200 (ok), not the expected status 404 (not found).
So it looks there are other redirects or a misconfiguration. Ah - loading the url manual, there is a big 404, so it's only the wrong http status.
That's good, now create there a file (file name 1234 with random content) and try to load this file via
http://partcatalog.ru/.well-known/acme-challenge/1234
If this works, you have found your correct webroot, so you can use
./letsencrypt-auto run -a webroot -i apache -w /var/www/partcatalog.ru -d partcatalog.ru
to create a new certificate.
Thank you very much! It all worked.
Yep, now it works.
But if you want, you can create one certificate with two names:
-d partcatalog.ru -d www.partcatalog.ru
Your current certificate has only one domain name, but www has a dns entry.
Different countries, different people. Some people add always www, some people add never www.
If you use one certificate with two domain names, both versions work.
