My domain is: en-sveta.ru
I ran this command: /etc/certbot/certbot-auto renew
/root/.local/share/letsencrypt/lib/python2.6/site-packages/cryptography/init.py:26: DeprecationWarning: Python 2.6 is no longer supported by the Python core team, please upgrade your Python. A future version of cryptography will drop support for Python 2.6
DeprecationWarning
Processing /etc/letsencrypt/renewal/en-sveta.ru.conf
http-01 challenge for en-sveta.ru
http-01 challenge for www.en-sveta.ru
Waiting for verification…
Attempting to renew cert from /etc/letsencrypt/renewal/en-sveta.ru.conf produced an unexpected error: Failed authorization procedure. en-sveta.ru (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://en-sveta.ru/.well-known/acme-challenge/p_itYqdH4ZCUUsW_dOgA0Mnb8oKBZwWez9Q-z2Yyvok: Timeout, www.en-sveta.ru (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://www.en-sveta.ru/.well-known/acme-challenge/texP98IYYosYPugeCFIlK9100bUuXP7c1Hz4xmotVow: Timeout. Skipping.
/etc/letsencrypt/live/en-sveta.ru/fullchain.pem (failure)
Domain: en-sveta.ru
Type: connection
Detail: Fetching
TimeoutDomain: www.en-sveta.ru
Type: connection
Detail: Fetching
TimeoutTo fix these errors, please make sure that your domain name was
or
DeprecationWarning
Attempting to renew cert from /etc/letsencrypt/renewal/en-sveta.ru.conf produced an unexpected error: urn:acme:error:rateLimited :: There were too many requests of a given type :: Error creating new authz :: Too many invalid authorizations recently… Skipping.
