I have a free hosting service which provides me with a third level domain and ssl certificate for that domain. I also own a second level domain, and I can manage the relevant DNS records. I tried to change the nameserver in order to point to the hosting address, and it works for http. Unfortunately but obviously, when I try an ssl connevtion I get an alert because the url and the certificate are different. Is there any free solution for this problem? Thank you.
Hi @Andreaconsole,
You can get a free certificate from Let’s Encrypt. However, not all hosting providers allow you to import externally-obtained certificates. So, you might not be able to use your Let’s Encrypt certificate to fix your problem unless you switch your hosting arrangements.
