My domain is: www.corauratum.com
It produced this output: usual timeout during connect
My web server is (include version): Nginx 1.15.12
The operating system my web server runs on is (include version): Ubuntu 16.04.6 LTS
My hosting provider, if applicable, is: Linode
I posted previously about the renewal issues I was having. Well once I got them resolved, I renewed the certificate with certbot renew and everything seemed fine. However now browsers are reporting that the certificate has expired. The certificate is good until July 2019, but the browsers are reporting the old date which was May 2, 2019. What’s the quickest way to fix this?
Hi @AndalayBay
the expired certificate is used ( https://check-your-website.server-daten.de/?q=corauratum.com ):
CN=corauratum.com
01.02.2019
02.05.2019
13 days expired
corauratum.com, test.corauratum.com,
www.corauratum.com - 3 entries
But there is a new certificate:
What says
certbot certificates
Perhaps try
certbot -d corauratum.com -d test.corauratum.com -d www.corauratum.com
Certbot should find the active certificate and should ask, if you want to install it.
@JuergenAuer that fixed it - thank you. However I think there’s something wrong with the certbot renew command then. Even when I ran the certbot -d command, it said that I could renew all my certificates with the renew command, which is what I did. I did look at the documentation and it also said to run certbot renew! The editor isn’t working for me, so I can’t format this reply properly.
It would be helpful to see the original output of certbot renew (but maybe you didn't save it?) and of certbot certificates in order to understand better what's happened here.
I have logging enabled and logrotate, so I’ll check the logs and see what I can find.
What's the content of your config file? A file in
/etc/letsencrypt/renewal
If there is certonly or no installer, that's the problem.
Running certonly -> renew doesn't install.
Here’s the conf file:
version = 0.31.0
archive_dir = /etc/letsencrypt/archive/corauratum.com
cert = /etc/letsencrypt/live/corauratum.com/cert.pem
privkey = /etc/letsencrypt/live/corauratum.com/privkey.pem
chain = /etc/letsencrypt/live/corauratum.com/chain.pem
fullchain = /etc/letsencrypt/live/corauratum.com/fullchain.pem
[renewalparams]
authenticator = webroot
account = *removed*
[[webroot_map]]
corauratum.com = /plexus/corauratum/prod
test.corauratum.com = /plexus/corauratum/test
www.corauratum.com = /plexus/corauratum/prod
The account is a long string of numbers, but I removed it from the text above just in case.
@schoen I have the logs, but I’m not sure what to post. Perhaps I could PM the contents to you?
If you run a command with explicit paramaters, Certbot changes your config file.
So check your domain in 60 - 65 days if the certificate is renewed.
