Web browsers not recognizing renewed certificate
I renewed a certificate several weeks ago, but the web browsers I'm using are showing the certificate has expired.
Although it wasn't a straightforward process (see Renew certificate failure) I did renew without errors several weeks ago and when I run the certbot certificates command it is showing 2021-03-14 as the next renewal date.
Why aren't my browsers accessing the renewed certificate details?
Steve
My domain is: www.catspaw.club
I ran this command: certbot certificates
Found the following certs:
Certificate Name: www.catspaw.club
Serial Number: ...
Domains: www.catspaw.club catspaw.club
Expiry Date: 2021-03-14 22:04:36+00:00 (VALID: 68 days)
My web server is (include version): nginx/1.18.0
The operating system my web server runs on is (include version): FreeBSD 12.1
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.8.0
Did you restart your webserver after the renewal?
I'm seeing this:
No. Just did now and it is working. Thanks.
Do know why the restart doesn't happen automatically or even why there is no restart reminder because I did renew with the nginx option:
$ certbot renew --cert-name www.catspaw.club -a nginx
Steve
Your redirects need help.
This:
http://catspaw.club
301 Moved Permanently
https://www.catspaw.club
200 OK
Should be this:
http://catspaw.club
https://catspaw.club
200 OK
This:
200 OK
Should be this:
200 OK
Ok. I'll work on that. Thanks.
Here's a command to fix things (run only once!):
certbot certonly --cert-name www.catspaw.club --nginx -d "www.catspaw.club,catspaw.club" --deploy-hook "nginx -s reload" --force-renewal
Then your renewal should just be:
certbot renew
