Hi! I dont know where that certificate came from.
when i run the commands as shown on https://certbot.eff.org/#ubuntutrusty-apache , this is the result i get:
bitnami@ip-172-31-4-162:~$ sudo certbot --apache certonly
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter ‘c’ to cancel): gamificagroup.com
tls-sni-01 challenge for gamificagroup.com
Enabled Apache socache_shmcb module
Enabled Apache ssl module
Error while running apache2ctl graceful.
httpd not running, trying to start
Action ‘graceful’ failed.
AH00112: Warning: DocumentRoot [/var/lib/letsencrypt/tls_sni_01_page/] does not exist
AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using 127.0.0.1. Set the ‘ServerName’ directive globally to suppress this message
(98)Address already in use: AH00072: make_sock: could not bind to address [::]:80
(98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
AH00015: Unable to open logs
Encountered exception during recovery
File “/usr/lib/python2.7/dist-packages/certbot/error_handler.py”, line 99, in _call_registered
self.funcs-1
File “/usr/lib/python2.7/dist-packages/certbot/auth_handler.py”, line 284, in _cleanup_challenges
self.auth.cleanup(achalls)
File “/usr/lib/python2.7/dist-packages/certbot_apache/configurator.py”, line 1910, in cleanup
self.restart()
File “/usr/lib/python2.7/dist-packages/certbot_apache/configurator.py”, line 1799, in restart
self._reload()
File “/usr/lib/python2.7/dist-packages/certbot_apache/configurator.py”, line 1810, in _reload
raise errors.MisconfigurationError(str(err))
MisconfigurationError: Error while running apache2ctl graceful.
Any suggestions?
