Bindings - hostname and SNI required
Hi Y’All
I have 40 odd sites running under IIS 10. Recent convert to LetsEncrypt
I need advice on how I should config IIS to use newly generated certs.
Should I set hostname field?
Should I tick Require Server Name Indication
How should bindings on default website be config’d
Your help gratefully received!
Russ
You need both.
hostname example.com + SNI
hostname www.example.com + SNI
A certificate with example.com and www.example.com, use this with these two bindings.
But normally the tool you use should do that.
