Autorenewal failure for reverse proxy in front of unicorn rails app
s16.ddoherty.net
certbot certonly --force-renew -d s16.ddoherty.net
Domain: s16.ddoherty.net
Type: connection
Detail: 76.201.154.172: Fetching http://s16.ddoherty.net/.well-known/acme-challenge/IYyMJC9_QhA_4UBqMfQQZlFG-u3GdPpMuS0Rm6BoP6o: Timeout during connect (likely firewall problem)
nginx version: nginx/1.18.0 (Ubuntu)
built with OpenSSL 3.0.2 15 Mar 2022
TLS SNI support enabled
configure arguments: --with-cc-opt='-g -O2 -ffile-prefix-map=/build/nginx-qDpDX0/nginx-1.18.0=. -flto=auto -ffat-lto-objects -flto=auto -ffat-lto-objects -fstack-protector-strong -Wformat -Werror=format-security -fPIC -Wdate-time -D_FORTIFY_SOURCE=2' --with-ld-opt='-Wl,-Bsymbolic-functions -flto=auto -ffat-lto-objects -flto=auto -Wl,-z,relro -Wl,-z,now -fPIC' --prefix=/usr/share/nginx --conf-path=/etc/nginx/nginx.conf --http-log-path=/var/log/nginx/access.log --error-log-path=/var/log/nginx/error.log --lock-path=/var/lock/nginx.lock --pid-path=/run/nginx.pid --modules-path=/usr/lib/nginx/modules --http-client-body-temp-path=/var/lib/nginx/body --http-fastcgi-temp-path=/var/lib/nginx/fastcgi --http-proxy-temp-path=/var/lib/nginx/proxy --http-scgi-temp-path=/var/lib/nginx/scgi --http-uwsgi-temp-path=/var/lib/nginx/uwsgi --with-compat --with-debug --with-pcre-jit --with-http_ssl_module --with-http_stub_status_module --with-http_realip_module --with-http_auth_request_module --with-http_v2_module --with-http_dav_module --with-http_slice_module --with-threads --add-dynamic-module=/build/nginx-qDpDX0/nginx-1.18.0/debian/modules/http-geoip2 --with-http_addition_module --with-http_gunzip_module --with-http_gzip_static_module --with-http_sub_module
Distributor ID: Ubuntu
Description: Ubuntu 22.04.1 LTS
Release: 22.04
Codename: jammy
self-hosted
Yea
No
2.8.0
My nginx config for the s16.ddoherty.net host is
  listen 80;
  server_name s16.ddoherty.net;
  return 301 https://$host$1$request_uri;
  listen 443 ssl http2;
  ssl_certificate /etc/letsencrypt/live/s16.ddoherty.net/fullchain.pem;
  ssl_certificate_key /etc/letsencrypt/live/s16.ddoherty.net/privkey.pem;
  client_max_body_size 4G;
  keepalive_timeout 10;
  error_page 500 502 504 /500.html;
  error_page 503 @503;
    proxy_pass http://unicorn_s16;
    proxy_set_header Host $host;
  location ~ /.well-known/acme-challenge {
    allow all;
    root /usr/share/nginx/html;
upstream unicorn_s16 {
  server s16.lan:8080;
Hello @ddoherty03, welcome to the Let's Encrypt community. :slightly_smiling_face:
Your Port 80 (and 443) are filtered; Best Practice - Keep Port 80 Open.
The HTTP-01 challenge of the Challenge Types - Let's Encrypt requires access to Port 80.
$ nmap -Pn -p80,443 s16.ddoherty.net
Starting Nmap 7.80 ( https://nmap.org ) at 2024-01-23 22:27 UTC
Nmap scan report for s16.ddoherty.net (76.201.154.172)
Host is up.
PORT    STATE    SERVICE
80/tcp  filtered http
443/tcp filtered https
Nmap done: 1 IP address (1 host up) scanned in 3.40 seconds
Gob smack. Yes, that seems to have been the problem!
Also, this doesn't "fix" anything that's broken:
Square peg... round hole.
Force it!
LOL
