Auto-SSL on GoDaddy
Hello,
GoDaddy is unable to help me locate or enable the auto-SSL feature. Did you have success with this? I was given below instructions but unable to locate the “Manage Users” tab in cPanel. Your help is appreciated.
https://documentation.cpanel.net/display/ALD/Manage+AutoSSL
Cheers,
BJ
If they don’t provide auto-SSL, you might check the following article:
https://isabelcastillo.com/lets-encrypt-ssl-certificate-godaddy-shared-cpanel
Please note that you are not limited to certbot, and might consider alternative clients if certbot for some reason does not seem to work for you. See - https://letsencrypt.org/docs/client-options/
