Any easy way 2025 for automatic renewal of SSL on Namecheap?
Hi, I have manually installed the cert via terminal on my Namecheap control panel, but wondering is there any easy way to get the cert automatically renewed?
I am very bad with all tech things, so a complicated way without every step tutorial is out of question. Even the words or the glossary you advanced tech people use goes over my head.
Thanks,
My domain is: floridagtinc.com
I ran this command: .acme.sh/acme.sh --issue -d floridagtinc.com -w /home/contprdg/floridagtinc.com/ --server letsencrypt
It produced this output: it works to get ssl for 3 months
The operating system my web server runs on is (include version): CloudLinux 8.x.
My hosting provider, if applicable, is: Namecheap
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): yes
Maybe certsage can help? Not sure if it's applicable to raw machine: what make you use cloudlinux without web panel?
In this case, perhaps obtaining your own cert is not worth your time and you'd be better finding a service for your site that handles the certificate for you or paying Namecheap to do the same.
