Acme.sh will not issue, says I am using verson 1 when I am using version 2
ytc1-cloud.dyndns.org
./acme.sh --issue -d ytc1.dyndns.org -d ytc1-cloud.dyndns.org --use-wget --test --apache --accountconf ${PWD}/account.conf
root@ytc1-cloud:/var/www/acme/.acme.sh# ./acme.sh -v
https://github.com/Neilpang/acme.sh
v2.8.0
[Sunday, 8 March 2020 at 18:00:47 GMT] Using stage ACME_DIRECTORY: https://acme-staging.api.letsencrypt.org/directory
[Sunday, 8 March 2020 at 18:00:49 GMT] Checking if there is an error in the apache config file before starting.
[Sunday, 8 March 2020 at 18:00:49 GMT] OK
[Sunday, 8 March 2020 at 18:00:50 GMT] JFYI, Config file /etc/apache2/2.4/httpd.conf is backuped to /root/.acme.sh/httpd.conf
[Sunday, 8 March 2020 at 18:00:50 GMT] In case there is an error that can not be restored automatically, you may try restore it yourself.
[Sunday, 8 March 2020 at 18:00:50 GMT] The backup file will be deleted on success, just forget it.
[Sunday, 8 March 2020 at 18:00:50 GMT] Registering account
[Sunday, 8 March 2020 at 18:00:52 GMT] Register account Error: {“type”:“urn:acme:error:unauthorized”,“detail”:“Account creation on ACMEv1 is disabled. Please upgrade your ACME client to a version that supports ACMEv2 / RFC 8555. See End of Life Plan for ACMEv1 for details.”,“status”: 403}
[Sunday, 8 March 2020 at 18:00:52 GMT] Please check log file for more details: /var/www/acme/.acme.sh/acme.sh.log
Apache 2.4
Solaris 11.4
Yes
No
./acme.sh -v
v2.8.0
You are using version 1 of the Let's Encrypt API. It's not about the version number of your ACME client.
Can you upgrade to a newer version of acme.sh? Version 2.8.0 is over a year old. I think it supports the ACMEv2 API but it evidently doesn't use it by default, and it might have bugs anyway.
That's the version 1 staging URL.
Ah, ok.
I ran acme.sh upgrade and this is the version it gave me.
Is there something else I should have run?
Right, I ran the upgrade again, and noticed it wrote to /root , when I was running from /var/www/acme/.acme.sh
I’ve copied into the correct dir and have moved forward, now another errror/issue, but wil leave that for another day. :slight_smile:
it writes it into /root and defines an alias, don’t copy that script, it will expect its data somewhere.
This is a Solaris zone, the / is immutable for security reasons.
I forgot I needed to do this, and use the --home variable.
All software needs to have roots and paths configurable. I wrongly assumed it would pick up/source the account.conf from the dir it was run from.
I’ll make notes.
It has been working this way for 2 years.
