Order's status (\"invalid\") is not acceptable for finalization
My domain is: yamacore.de
I ran this command: acme.sh --issue --dns dns_netcup --dnssleep 30 -d '*.yamacore.de' -d 'yamacore.de' --debug
[Wed May 5 12:16:44 UTC 2021] Lets find script dir.
[Wed May 5 12:16:44 UTC 2021] SCRIPT ='/root/.acme.sh/acme.sh'
[Wed May 5 12:16:44 UTC 2021] _script='/root/.acme.sh/acme.sh'
[Wed May 5 12:16:44 UTC 2021] _script_home='/root/.acme.sh'
[Wed May 5 12:16:44 UTC 2021] Using default home:/root/.acme.sh
[Wed May 5 12:16:44 UTC 2021] Using config home:/acme.sh
v2.8.9
[Wed May 5 12:16:44 UTC 2021] Running cmd: issue
[Wed May 5 12:16:44 UTC 2021] _main_domain=' .yamacore.de'
[Wed May 5 12:16:44 UTC 2021] _alt_domains='yamacore.de'
[Wed May 5 12:16:44 UTC 2021] Using ACME_DIRECTORY: https://acme-staging-v02.api.letsencrypt.org/directory
[Wed May 5 12:16:44 UTC 2021] ACME_DIRECTORY='https://acme-staging-v02.api.letsencrypt.org/directory'
[Wed May 5 12:16:44 UTC 2021] DOMAIN_PATH='/acme.sh/
.yamacore.de'
[Wed May 5 12:16:44 UTC 2021] _init api for server: https://acme-staging-v02.api.letsencrypt.org/directory
[Wed May 5 12:16:44 UTC 2021] GET
[Wed May 5 12:16:44 UTC 2021] url='https://acme-staging-v02.api.letsencrypt.org/directory'
[Wed May 5 12:16:44 UTC 2021] timeout=
[Wed May 5 12:16:44 UTC 2021] _CURL='curl --silent --dump-header /acme.sh/http.header -L '
[Wed May 5 12:16:45 UTC 2021] ret='0'
[Wed May 5 12:16:45 UTC 2021] ACME_KEY_CHANGE='https://acme-staging-v02.api.letsencrypt.org/acme/key-change'
[Wed May 5 12:16:45 UTC 2021] ACME_NEW_AUTHZ
[Wed May 5 12:16:45 UTC 2021] ACME_NEW_ORDER='https://acme-staging-v02.api.letsencrypt.org/acme/new-order'
[Wed May 5 12:16:45 UTC 2021] ACME_NEW_ACCOUNT='https://acme-staging-v02.api.letsencrypt.org/acme/new-acct'
[Wed May 5 12:16:45 UTC 2021] ACME_REVOKE_CERT='https://acme-staging-v02.api.letsencrypt.org/acme/revoke-cert'
[Wed May 5 12:16:45 UTC 2021] ACME_AGREEMENT='https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf'
[Wed May 5 12:16:45 UTC 2021] ACME_NEW_NONCE='https://acme-staging-v02.api.letsencrypt.org/acme/new-nonce'
[Wed May 5 12:16:45 UTC 2021] ACME_VERSION='2'
[Wed May 5 12:16:45 UTC 2021] Le_NextRenewTime
[Wed May 5 12:16:45 UTC 2021] Using CA: https://acme-staging-v02.api.letsencrypt.org/directory
[Wed May 5 12:16:45 UTC 2021] _on_before_issue
[Wed May 5 12:16:45 UTC 2021] _chk_main_domain=' .yamacore.de'
[Wed May 5 12:16:45 UTC 2021] _chk_alt_domains='yamacore.de'
[Wed May 5 12:16:45 UTC 2021] Le_LocalAddress
[Wed May 5 12:16:45 UTC 2021] d='
.yamacore.de'
[Wed May 5 12:16:45 UTC 2021] Check for domain=' .yamacore.de'
[Wed May 5 12:16:45 UTC 2021] _currentRoot='dns_netcup'
[Wed May 5 12:16:45 UTC 2021] d='yamacore.de'
[Wed May 5 12:16:45 UTC 2021] Check for domain='yamacore.de'
[Wed May 5 12:16:45 UTC 2021] config file is empty, can not read CA_KEY_HASH
[Wed May 5 12:16:45 UTC 2021] Using config home:/acme.sh
[Wed May 5 12:16:45 UTC 2021] ACME_DIRECTORY='https://acme-staging-v02.api.letsencrypt.org/directory'
[Wed May 5 12:16:45 UTC 2021] _init api for server: https://acme-staging-v02.api.letsencrypt.org/directory
[Wed May 5 12:16:45 UTC 2021] Use default length 2048
[Wed May 5 12:16:45 UTC 2021] length='2048'
[Wed May 5 12:16:45 UTC 2021] Use length 2048
[Wed May 5 12:16:45 UTC 2021] Using RSA: 2048
[Wed May 5 12:16:45 UTC 2021] Create account key ok.
[Wed May 5 12:16:45 UTC 2021] RSA key
[Wed May 5 12:16:45 UTC 2021] config file is empty, can not read CA_EAB_KEY_ID
[Wed May 5 12:16:45 UTC 2021] config file is empty, can not read CA_EAB_HMAC_KEY
[Wed May 5 12:16:45 UTC 2021] config file is empty, can not read CA_EMAIL
[Wed May 5 12:16:45 UTC 2021] Registering account: https://acme-staging-v02.api.letsencrypt.org/directory
[Wed May 5 12:16:45 UTC 2021] url='https://acme-staging-v02.api.letsencrypt.org/acme/new-acct'
[Wed May 5 12:16:45 UTC 2021] payload='{"termsOfServiceAgreed": true}'
[Wed May 5 12:16:45 UTC 2021] HEAD
[Wed May 5 12:16:45 UTC 2021] _post_url='https://acme-staging-v02.api.letsencrypt.org/acme/new-nonce'
[Wed May 5 12:16:45 UTC 2021] _CURL='curl --silent --dump-header /acme.sh/http.header -L -I '
[Wed May 5 12:16:46 UTC 2021] _ret='0'
[Wed May 5 12:16:46 UTC 2021] POST
[Wed May 5 12:16:46 UTC 2021] _post_url='https://acme-staging-v02.api.letsencrypt.org/acme/new-acct'
[Wed May 5 12:16:46 UTC 2021] _CURL='curl --silent --dump-header /acme.sh/http.header -L '
[Wed May 5 12:16:47 UTC 2021] _ret='0'
[Wed May 5 12:16:47 UTC 2021] code='201'
[Wed May 5 12:16:47 UTC 2021] Registered
[Wed May 5 12:16:47 UTC 2021] _accUri='https://acme-staging-v02.api.letsencrypt.org/acme/acct/19389032'
[Wed May 5 12:16:47 UTC 2021] Calc CA_KEY_HASH='C6x2F5b0CXog+AxFjOyzHaTt+cnYdKR801d8YlfdIds='
[Wed May 5 12:16:47 UTC 2021] ACCOUNT_THUMBPRINT='p3wmobNz_dL4EPBV0XG1ex85BDZdAF0xcUgz4ipbSrI'
[Wed May 5 12:16:47 UTC 2021] Read key length:
[Wed May 5 12:16:47 UTC 2021] _createcsr
[Wed May 5 12:16:47 UTC 2021] Multi domain='DNS:
.yamacore.de,DNS:yamacore.de'
[Wed May 5 12:16:47 UTC 2021] Getting domain auth token for each domain
[Wed May 5 12:16:47 UTC 2021] d='yamacore.de'
[Wed May 5 12:16:47 UTC 2021] url='https://acme-staging-v02.api.letsencrypt.org/acme/new-order'
[Wed May 5 12:16:47 UTC 2021] payload='{"identifiers": [{"type":"dns","value":" .yamacore.de"},{"type":"dns","value":"yamacore.de"}]}'
[Wed May 5 12:16:47 UTC 2021] POST
[Wed May 5 12:16:47 UTC 2021] _post_url='https://acme-staging-v02.api.letsencrypt.org/acme/new-order'
[Wed May 5 12:16:47 UTC 2021] _CURL='curl --silent --dump-header /acme.sh/http.header -L '
[Wed May 5 12:16:48 UTC 2021] _ret='0'
[Wed May 5 12:16:48 UTC 2021] code='201'
[Wed May 5 12:16:48 UTC 2021] Le_LinkOrder='https://acme-staging-v02.api.letsencrypt.org/acme/order/19389032/46298443'
[Wed May 5 12:16:48 UTC 2021] Le_OrderFinalize='https://acme-staging-v02.api.letsencrypt.org/acme/finalize/19389032/46298443'
[Wed May 5 12:16:48 UTC 2021] url='https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/41499471'
[Wed May 5 12:16:48 UTC 2021] payload
[Wed May 5 12:16:48 UTC 2021] POST
[Wed May 5 12:16:48 UTC 2021] _post_url='https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/41499471'
[Wed May 5 12:16:48 UTC 2021] _CURL='curl --silent --dump-header /acme.sh/http.header -L '
[Wed May 5 12:16:48 UTC 2021] code='200'
[Wed May 5 12:16:48 UTC 2021] url='https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/41499472'
[Wed May 5 12:16:48 UTC 2021] _post_url='https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/41499472'
[Wed May 5 12:16:49 UTC 2021] _ret='0'
[Wed May 5 12:16:49 UTC 2021] code='200'
[Wed May 5 12:16:49 UTC 2021] d='
.yamacore.de'
[Wed May 5 12:16:49 UTC 2021] Getting webroot for domain=' .yamacore.de'
[Wed May 5 12:16:49 UTC 2021] _w='dns_netcup'
[Wed May 5 12:16:49 UTC 2021] _currentRoot='dns_netcup'
[Wed May 5 12:16:49 UTC 2021] entry='"type":"dns-01","status":"pending","url":"https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/41499471/-YQ2rQ","token":"oKFi-DUGFfXkpHUxbrPIjtrYsFcwFClCHrJGVKg9Yho"'
[Wed May 5 12:16:49 UTC 2021] token='oKFi-DUGFfXkpHUxbrPIjtrYsFcwFClCHrJGVKg9Yho'
[Wed May 5 12:16:49 UTC 2021] uri='https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/41499471/-YQ2rQ'
[Wed May 5 12:16:49 UTC 2021] keyauthorization='oKFi-DUGFfXkpHUxbrPIjtrYsFcwFClCHrJGVKg9Yho.p3wmobNz_dL4EPBV0XG1ex85BDZdAF0xcUgz4ipbSrI'
[Wed May 5 12:16:49 UTC 2021] dvlist='
.yamacore.de#oKFi-DUGFfXkpHUxbrPIjtrYsFcwFClCHrJGVKg9Yho.p3wmobNz_dL4EPBV0XG1ex85BDZdAF0xcUgz4ipbSrI#https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/41499471/-YQ2rQ#dns-01#dns_netcup'
[Wed May 5 12:16:49 UTC 2021] d='yamacore.de'
[Wed May 5 12:16:49 UTC 2021] Getting webroot for domain='yamacore.de'
[Wed May 5 12:16:49 UTC 2021] entry='"type":"dns-01","status":"pending","url":"https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/41499472/l1ZL-g","token":"-jwR9xR9GLcfoJu_eoqBTYAp5WbFQdcJcA3Tne07vw8"'
[Wed May 5 12:16:49 UTC 2021] token='-jwR9xR9GLcfoJu_eoqBTYAp5WbFQdcJcA3Tne07vw8'
[Wed May 5 12:16:49 UTC 2021] uri='https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/41499472/l1ZL-g'
[Wed May 5 12:16:49 UTC 2021] keyauthorization='-jwR9xR9GLcfoJu_eoqBTYAp5WbFQdcJcA3Tne07vw8.p3wmobNz_dL4EPBV0XG1ex85BDZdAF0xcUgz4ipbSrI'
[Wed May 5 12:16:49 UTC 2021] dvlist='yamacore.de#-jwR9xR9GLcfoJu_eoqBTYAp5WbFQdcJcA3Tne07vw8.p3wmobNz_dL4EPBV0XG1ex85BDZdAF0xcUgz4ipbSrI#https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/41499472/l1ZL-g#dns-01#dns_netcup'
[Wed May 5 12:16:49 UTC 2021] vlist=' .yamacore.de#oKFi-DUGFfXkpHUxbrPIjtrYsFcwFClCHrJGVKg9Yho.p3wmobNz_dL4EPBV0XG1ex85BDZdAF0xcUgz4ipbSrI#https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/41499471/-YQ2rQ#dns-01#dns_netcup,yamacore.de#-jwR9xR9GLcfoJu_eoqBTYAp5WbFQdcJcA3Tne07vw8.p3wmobNz_dL4EPBV0XG1ex85BDZdAF0xcUgz4ipbSrI#https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/41499472/l1ZL-g#dns-01#dns_netcup,'
.yamacore.de'
[Wed May 5 12:16:49 UTC 2021] _d_alias
[Wed May 5 12:16:49 UTC 2021] txtdomain='_acme-challenge.yamacore.de'
[Wed May 5 12:16:49 UTC 2021] txt='uORcuU6WQEDV1FcGoKSJVhdRQ8Y-sNqvUke6jdY-V70'
[Wed May 5 12:16:49 UTC 2021] d_api='/root/.acme.sh/dnsapi/dns_netcup.sh'
[Wed May 5 12:16:49 UTC 2021] Found domain api file: /root/.acme.sh/dnsapi/dns_netcup.sh
[Wed May 5 12:16:49 UTC 2021] Adding txt value: uORcuU6WQEDV1FcGoKSJVhdRQ8Y-sNqvUke6jdY-V70 for domain: _acme-challenge.yamacore.de
[Wed May 5 12:16:49 UTC 2021] NC_Apikey=' '
[Wed May 5 12:16:49 UTC 2021] POST
[Wed May 5 12:16:49 UTC 2021] _post_url='https://ccp.netcup.net/run/webservice/servers/endpoint.php?JSON'
[Wed May 5 12:16:49 UTC 2021] _CURL='curl --silent --dump-header /acme.sh/http.header -L '
[Wed May 5 12:16:50 UTC 2021] _ret='0'
[Wed May 5 12:16:50 UTC 2021] {"serverrequestid":"VDEMT00SzGGd=hFZH","clientrequestid":"","action":"login","status":"success","statuscode":2000,"shortmessage":"Login successful","longmessage":"Session has been created successful.","responsedata":{"apisessionid":"ZTkyM3A1ODc0ZzE2OXZBbW9IYVRqR2JyU2ZCUm1RSTUyVDUxQj"}}
[Wed May 5 12:16:50 UTC 2021] POST
[Wed May 5 12:16:50 UTC 2021] _post_url='https://ccp.netcup.net/run/webservice/servers/endpoint.php?JSON'
[Wed May 5 12:16:50 UTC 2021] _CURL='curl --silent --dump-header /acme.sh/http.header -L '
[Wed May 5 12:16:52 UTC 2021] _ret='0'
[Wed May 5 12:16:52 UTC 2021] {"serverrequestid":"335z8NMVU2dN034jGT46kLlc9dDg","clientrequestid":"","action":"updateDnsRecords","status":"success","statuscode":2000,"shortmessage":"DNS records successful updated","longmessage":"The given DNS records for this zone were updated.","responsedata":{"dnsrecords":[{"id":"15812934","hostname":" ","type":"A","priority":"0","destination":"46.38.253.171","deleterecord":false,"state":"yes"},{"id":"15812936","hostname":" ","type":"A","priority":"0","destination":"185.170.115.235","deleterecord":false,"state":"yes"},{"id":"15812937","hostname":" ","type":"A","priority":"0","destination":"185.170.113.121","deleterecord":false,"state":"yes"},{"id":"15812938","hostname":" ","type":"A","priority":"0","destination":"188.68.39.242","deleterecord":false,"state":"yes"},{"id":"5852469","hostname":"@","type":"A","priority":"0","destination":"188.68.47.15","deleterecord":false,"state":"yes"},{"id":"5852471","hostname":"@","type":"AAAA","priority":"0","destination":"2a03:4000:30:1f20::10:8047","deleterecord":false,"state":"yes"},{"id":"5852472","hostname":"@","type":"TXT","priority":"0","destination":"v=spf1 mx a include:_spf.webhosting.systems ~all","deleterecord":false,"state":"yes"},{"id":"5852474","hostname":"@","type":"MX","priority":"10","destination":"mail.yamacore.de","deleterecord":false,"state":"yes"},{"id":"5852475","hostname":"@","type":"MX","priority":"50","destination":"mx2f11.netcup.net","deleterecord":false,"state":"yes"},{"id":"5852477","hostname":"autoconfig","type":"CNAME","priority":"0","destination":"autoconfig.netcup.net","deleterecord":false,"state":"yes"},{"id":"13767728","hostname":"cluster","type":"A","priority":"0","destination":"185.170.113.121","deleterecord":false,"state":"yes"},{"id":"13767729","hostname":"cluster","type":"A","priority":"0","destination":"188.68.39.242","deleterecord":false,"state":"yes"},{"id":"11953281","hostname":"cluster","type":"A","priority":"0","destination":"185.170.115.235","deleterecord":false,"state":"yes"},{"id":"12064674","hostname":"cluster","type":"A","priority":"0","destination":"46.38.253.171","deleterecord":false,"state":"yes"},{"id":"5852476","hostname":"db","type":"A","priority":"0","destination":"188.68.47.16","deleterecord":false,"state":"yes"},{"id":"6058713","hostname":"extern","type":"CNAME","priority":"0","destination":"cluster.yamacore.de","deleterecord":false,"state":"yes"},{"id":"5924404","hostname":"intern","type":"CNAME","priority":"0","destination":"intern.yamacore.org","deleterecord":false,"state":"yes"},{"id":"5852473","hostname":"mail","type":"A","priority":"0","destination":"188.68.47.17","deleterecord":false,"state":"yes"},{"id":"5863014","hostname":"webmail","type":"A","priority":"0","destination":"188.68.47.17","deleterecord":false,"state":"yes"},{"id":"12061993","hostname":"Y-Cluster-VPS-Node1","type":"A","priority":"0","destination":"46.38.253.171","deleterecord":false,"state":"yes"},{"id":"11878885","hostname":"Y-Cluster-VPS-Node2","type":"A","priority":"0","destination":"185.170.113.121","deleterecord":false,"state":"yes"},{"id":"11878886","hostname":"Y-Cluster-VPS-Node3","type":"A","priority":"0","destination":"188.68.39.242","deleterecord":false,"state":"yes"},{"id":"11878887","hostname":"Y-Cluster-VPS-Node4","type":"A","priority":"0","destination":"185.170.115.235","deleterecord":false,"state":"yes"},{"id":"6058714","hostname":"yamacoreapp","type":"CNAME","priority":"0","destination":"cluster.yamacore.de","deleterecord":false,"state":"yes"},{"id":"36155407","hostname":"_acme-challenge","type":"TXT","priority":"0","destination":"uORcuU6WQEDV1FcGoKSJVhdRQ8Y-sNqvUke6jdY-V70","deleterecord":false,"state":"unknown"}]}}
[Wed May 5 12:16:52 UTC 2021] POST
[Wed May 5 12:16:52 UTC 2021] _post_url='https://ccp.netcup.net/run/webservice/servers/endpoint.php?JSON'
[Wed May 5 12:16:52 UTC 2021] _CURL='curl --silent --dump-header /acme.sh/http.header -L '
[Wed May 5 12:16:52 UTC 2021] {"serverrequestid":"MWUEe0zXwdY1hU=sS","clientrequestid":"","action":"logout","status":"success","statuscode":2000,"shortmessage":"Logout successful","longmessage":"Session has been terminated successful.","responsedata":""}
[Wed May 5 12:16:52 UTC 2021] The txt record is added: Success.
[Wed May 5 12:16:52 UTC 2021] d='yamacore.de'
[Wed May 5 12:16:52 UTC 2021] _d_alias
[Wed May 5 12:16:52 UTC 2021] txtdomain='_acme-challenge.yamacore.de'
[Wed May 5 12:16:52 UTC 2021] txt='s6PFGSsVLw3i-JsqD-6n5pmK3LjgVFABGeAwxLN2nuA'
[Wed May 5 12:16:52 UTC 2021] d_api='/root/.acme.sh/dnsapi/dns_netcup.sh'
[Wed May 5 12:16:52 UTC 2021] Found domain api file: /root/.acme.sh/dnsapi/dns_netcup.sh
[Wed May 5 12:16:52 UTC 2021] Adding txt value: s6PFGSsVLw3i-JsqD-6n5pmK3LjgVFABGeAwxLN2nuA for domain: _acme-challenge.yamacore.de
[Wed May 5 12:16:52 UTC 2021] NC_Apikey='
[Wed May 5 12:16:53 UTC 2021] _ret='0'
[Wed May 5 12:16:53 UTC 2021] {"serverrequestid":"j=UWa3DcswNI0EzQZ","clientrequestid":"","action":"login","status":"success","statuscode":2000,"shortmessage":"Login successful","longmessage":"Session has been created successful.","responsedata":{"apisessionid":"MzJkQzUxOTY4czQ3Q3ZBbW9IYVRqR2JyU2ZCUm1RSTU4dTJNMz"}}
[Wed May 5 12:16:53 UTC 2021] POST
[Wed May 5 12:16:53 UTC 2021] _post_url='https://ccp.netcup.net/run/webservice/servers/endpoint.php?JSON'
[Wed May 5 12:16:53 UTC 2021] _CURL='curl --silent --dump-header /acme.sh/http.header -L '
[Wed May 5 12:16:55 UTC 2021] _ret='0'
[Wed May 5 12:16:55 UTC 2021] {"serverrequestid":"J5UN1M35V8M0GX9VjWN35Z42EoT6","clientrequestid":"","action":"updateDnsRecords","status":"success","statuscode":2000,"shortmessage":"DNS records successful updated","longmessage":"The given DNS records for this zone were updated.","responsedata":{"dnsrecords":[{"id":"15812934","hostname":" ","type":"A","priority":"0","destination":"46.38.253.171","deleterecord":false,"state":"yes"},{"id":"15812936","hostname":" ","type":"A","priority":"0","destination":"185.170.115.235","deleterecord":false,"state":"yes"},{"id":"15812937","hostname":" ","type":"A","priority":"0","destination":"185.170.113.121","deleterecord":false,"state":"yes"},{"id":"15812938","hostname":" ","type":"A","priority":"0","destination":"188.68.39.242","deleterecord":false,"state":"yes"},{"id":"5852469","hostname":"@","type":"A","priority":"0","destination":"188.68.47.15","deleterecord":false,"state":"yes"},{"id":"5852471","hostname":"@","type":"AAAA","priority":"0","destination":"2a03:4000:30:1f20::10:8047","deleterecord":false,"state":"yes"},{"id":"5852472","hostname":"@","type":"TXT","priority":"0","destination":"v=spf1 mx a include:_spf.webhosting.systems ~all","deleterecord":false,"state":"yes"},{"id":"5852474","hostname":"@","type":"MX","priority":"10","destination":"mail.yamacore.de","deleterecord":false,"state":"yes"},{"id":"5852475","hostname":"@","type":"MX","priority":"50","destination":"mx2f11.netcup.net","deleterecord":false,"state":"yes"},{"id":"5852477","hostname":"autoconfig","type":"CNAME","priority":"0","destination":"autoconfig.netcup.net","deleterecord":false,"state":"yes"},{"id":"13767728","hostname":"cluster","type":"A","priority":"0","destination":"185.170.113.121","deleterecord":false,"state":"yes"},{"id":"13767729","hostname":"cluster","type":"A","priority":"0","destination":"188.68.39.242","deleterecord":false,"state":"yes"},{"id":"11953281","hostname":"cluster","type":"A","priority":"0","destination":"185.170.115.235","deleterecord":false,"state":"yes"},{"id":"12064674","hostname":"cluster","type":"A","priority":"0","destination":"46.38.253.171","deleterecord":false,"state":"yes"},{"id":"5852476","hostname":"db","type":"A","priority":"0","destination":"188.68.47.16","deleterecord":false,"state":"yes"},{"id":"6058713","hostname":"extern","type":"CNAME","priority":"0","destination":"cluster.yamacore.de","deleterecord":false,"state":"yes"},{"id":"5924404","hostname":"intern","type":"CNAME","priority":"0","destination":"intern.yamacore.org","deleterecord":false,"state":"yes"},{"id":"5852473","hostname":"mail","type":"A","priority":"0","destination":"188.68.47.17","deleterecord":false,"state":"yes"},{"id":"5863014","hostname":"webmail","type":"A","priority":"0","destination":"188.68.47.17","deleterecord":false,"state":"yes"},{"id":"12061993","hostname":"Y-Cluster-VPS-Node1","type":"A","priority":"0","destination":"46.38.253.171","deleterecord":false,"state":"yes"},{"id":"11878885","hostname":"Y-Cluster-VPS-Node2","type":"A","priority":"0","destination":"185.170.113.121","deleterecord":false,"state":"yes"},{"id":"11878886","hostname":"Y-Cluster-VPS-Node3","type":"A","priority":"0","destination":"188.68.39.242","deleterecord":false,"state":"yes"},{"id":"11878887","hostname":"Y-Cluster-VPS-Node4","type":"A","priority":"0","destination":"185.170.115.235","deleterecord":false,"state":"yes"},{"id":"6058714","hostname":"yamacoreapp","type":"CNAME","priority":"0","destination":"cluster.yamacore.de","deleterecord":false,"state":"yes"},{"id":"36155407","hostname":"_acme-challenge","type":"TXT","priority":"0","destination":"uORcuU6WQEDV1FcGoKSJVhdRQ8Y-sNqvUke6jdY-V70","deleterecord":false,"state":"unknown"},{"id":"36155408","hostname":"_acme-challenge","type":"TXT","priority":"0","destination":"s6PFGSsVLw3i-JsqD-6n5pmK3LjgVFABGeAwxLN2nuA","deleterecord":false,"state":"unknown"}]}}
[Wed May 5 12:16:55 UTC 2021] POST
[Wed May 5 12:16:55 UTC 2021] _post_url='https://ccp.netcup.net/run/webservice/servers/endpoint.php?JSON'
[Wed May 5 12:16:55 UTC 2021] _CURL='curl --silent --dump-header /acme.sh/http.header -L '
[Wed May 5 12:16:55 UTC 2021] {"serverrequestid":"R1SmYm=ZY4wtwD0YN","clientrequestid":"","action":"logout","status":"success","statuscode":2000,"shortmessage":"Logout successful","longmessage":"Session has been terminated successful.","responsedata":""}
[Wed May 5 12:16:55 UTC 2021] The txt record is added: Success.
[Wed May 5 12:16:55 UTC 2021] Sleep 30 seconds for the txt records to take effect
[Wed May 5 12:17:25 UTC 2021] ok, let's start to verify
[Wed May 5 12:17:25 UTC 2021] Verifying: .yamacore.de
[Wed May 5 12:17:25 UTC 2021] d='
.yamacore.de'
[Wed May 5 12:17:25 UTC 2021] keyauthorization='oKFi-DUGFfXkpHUxbrPIjtrYsFcwFClCHrJGVKg9Yho.p3wmobNz_dL4EPBV0XG1ex85BDZdAF0xcUgz4ipbSrI'
[Wed May 5 12:17:25 UTC 2021] uri='https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/41499471/-YQ2rQ'
[Wed May 5 12:17:26 UTC 2021] _currentRoot='dns_netcup'
[Wed May 5 12:17:26 UTC 2021] url='https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/41499471/-YQ2rQ'
[Wed May 5 12:17:26 UTC 2021] payload='{}'
[Wed May 5 12:17:26 UTC 2021] POST
[Wed May 5 12:17:26 UTC 2021] _post_url='https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/41499471/-YQ2rQ'
[Wed May 5 12:17:26 UTC 2021] _CURL='curl --silent --dump-header /acme.sh/http.header -L '
[Wed May 5 12:17:26 UTC 2021] _ret='0'
[Wed May 5 12:17:26 UTC 2021] code='200'
[Wed May 5 12:17:26 UTC 2021] trigger validation code: 200
[Wed May 5 12:17:26 UTC 2021] sleep 2 secs to verify
[Wed May 5 12:17:28 UTC 2021] checking
[Wed May 5 12:17:28 UTC 2021] url='https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/41499471/-YQ2rQ'
[Wed May 5 12:17:28 UTC 2021] payload
[Wed May 5 12:17:28 UTC 2021] POST
[Wed May 5 12:17:28 UTC 2021] _post_url='https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/41499471/-YQ2rQ'
[Wed May 5 12:17:28 UTC 2021] _CURL='curl --silent --dump-header /acme.sh/http.header -L '
[Wed May 5 12:17:29 UTC 2021] _ret='0'
[Wed May 5 12:17:29 UTC 2021] code='200'
[Wed May 5 12:17:29 UTC 2021] Success
[Wed May 5 12:17:29 UTC 2021] pid
[Wed May 5 12:17:29 UTC 2021] Skip for removelevel:
[Wed May 5 12:17:29 UTC 2021] Verifying: yamacore.de
[Wed May 5 12:17:29 UTC 2021] d='yamacore.de'
[Wed May 5 12:17:29 UTC 2021] keyauthorization='-jwR9xR9GLcfoJu_eoqBTYAp5WbFQdcJcA3Tne07vw8.p3wmobNz_dL4EPBV0XG1ex85BDZdAF0xcUgz4ipbSrI'
[Wed May 5 12:17:29 UTC 2021] uri='https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/41499472/l1ZL-g'
[Wed May 5 12:17:29 UTC 2021] _currentRoot='dns_netcup'
[Wed May 5 12:17:29 UTC 2021] url='https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/41499472/l1ZL-g'
[Wed May 5 12:17:29 UTC 2021] payload='{}'
[Wed May 5 12:17:29 UTC 2021] POST
[Wed May 5 12:17:29 UTC 2021] _post_url='https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/41499472/l1ZL-g'
[Wed May 5 12:17:29 UTC 2021] _CURL='curl --silent --dump-header /acme.sh/http.header -L '
[Wed May 5 12:17:30 UTC 2021] _ret='0'
[Wed May 5 12:17:30 UTC 2021] code='200'
[Wed May 5 12:17:30 UTC 2021] trigger validation code: 200
[Wed May 5 12:17:30 UTC 2021] sleep 2 secs to verify
[Wed May 5 12:17:32 UTC 2021] checking
[Wed May 5 12:17:32 UTC 2021] url='https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/41499472/l1ZL-g'
[Wed May 5 12:17:32 UTC 2021] payload
[Wed May 5 12:17:32 UTC 2021] POST
[Wed May 5 12:17:32 UTC 2021] _post_url='https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/41499472/l1ZL-g'
[Wed May 5 12:17:32 UTC 2021] _CURL='curl --silent --dump-header /acme.sh/http.header -L '
[Wed May 5 12:17:33 UTC 2021] _ret='0'
[Wed May 5 12:17:33 UTC 2021] code='200'
[Wed May 5 12:17:33 UTC 2021] Success
[Wed May 5 12:17:33 UTC 2021] pid
[Wed May 5 12:17:33 UTC 2021] Skip for removelevel:
[Wed May 5 12:17:33 UTC 2021] No need to restore nginx, skip.
[Wed May 5 12:17:33 UTC 2021] _clearupdns
[Wed May 5 12:17:33 UTC 2021] dns_entries='yamacore.de,_acme-challenge.yamacore.de,,dns_netcup,uORcuU6WQEDV1FcGoKSJVhdRQ8Y-sNqvUke6jdY-V70,/root/.acme.sh/dnsapi/dns_netcup.sh
yamacore.de,_acme-challenge.yamacore.de,,dns_netcup,s6PFGSsVLw3i-JsqD-6n5pmK3LjgVFABGeAwxLN2nuA,/root/.acme.sh/dnsapi/dns_netcup.sh
[Wed May 5 12:17:33 UTC 2021] Removing DNS records.
[Wed May 5 12:17:33 UTC 2021] d='yamacore.de'
[Wed May 5 12:17:33 UTC 2021] txtdomain='_acme-challenge.yamacore.de'
[Wed May 5 12:17:33 UTC 2021] aliasDomain='_acme-challenge.yamacore.de'
[Wed May 5 12:17:33 UTC 2021] _currentRoot='dns_netcup'
[Wed May 5 12:17:33 UTC 2021] txt='uORcuU6WQEDV1FcGoKSJVhdRQ8Y-sNqvUke6jdY-V70'
[Wed May 5 12:17:33 UTC 2021] d_api='/root/.acme.sh/dnsapi/dns_netcup.sh'
[Wed May 5 12:17:33 UTC 2021] Removing txt: uORcuU6WQEDV1FcGoKSJVhdRQ8Y-sNqvUke6jdY-V70 for domain: _acme-challenge.yamacore.de
[Wed May 5 12:17:33 UTC 2021] POST
[Wed May 5 12:17:33 UTC 2021] _post_url='https://ccp.netcup.net/run/webservice/servers/endpoint.php?JSON'
[Wed May 5 12:17:33 UTC 2021] _CURL='curl --silent --dump-header /acme.sh/http.header -L '
[Wed May 5 12:17:34 UTC 2021] _ret='0'
[Wed May 5 12:17:34 UTC 2021] {"serverrequestid":"rjnM4NHMNY=aZYFH0","clientrequestid":"","action":"login","status":"success","statuscode":2000,"shortmessage":"Login successful","longmessage":"Session has been created successful.","responsedata":{"apisessionid":"NFUxNzk4VDUyMzZubnZBbW9IYVRqR2JyU2ZCUm1RSTV2NDczbj"}}
[Wed May 5 12:17:34 UTC 2021] POST
[Wed May 5 12:17:34 UTC 2021] _post_url='https://ccp.netcup.net/run/webservice/servers/endpoint.php?JSON'
[Wed May 5 12:17:34 UTC 2021] _CURL='curl --silent --dump-header /acme.sh/http.header -L '
[Wed May 5 12:17:34 UTC 2021] {"serverrequestid":"adwn0ZQCN=3R0jX4N","clientrequestid":"","action":"infoDnsRecords","status":"success","statuscode":2000,"shortmessage":"DNS records found","longmessage":"DNS Records for this zone were found.","responsedata":{"dnsrecords":[{"id":"15812934","hostname":" ","type":"A","priority":"0","destination":"46.38.253.171","deleterecord":false,"state":"yes"},{"id":"15812936","hostname":" ","type":"A","priority":"0","destination":"185.170.115.235","deleterecord":false,"state":"yes"},{"id":"15812937","hostname":" ","type":"A","priority":"0","destination":"185.170.113.121","deleterecord":false,"state":"yes"},{"id":"15812938","hostname":" ","type":"A","priority":"0","destination":"188.68.39.242","deleterecord":false,"state":"yes"},{"id":"5852469","hostname":"@","type":"A","priority":"0","destination":"188.68.47.15","deleterecord":false,"state":"yes"},{"id":"5852471","hostname":"@","type":"AAAA","priority":"0","destination":"2a03:4000:30:1f20::10:8047","deleterecord":false,"state":"yes"},{"id":"5852472","hostname":"@","type":"TXT","priority":"0","destination":"v=spf1 mx a include:_spf.webhosting.systems ~all","deleterecord":false,"state":"yes"},{"id":"5852474","hostname":"@","type":"MX","priority":"10","destination":"mail.yamacore.de","deleterecord":false,"state":"yes"},{"id":"5852475","hostname":"@","type":"MX","priority":"50","destination":"mx2f11.netcup.net","deleterecord":false,"state":"yes"},{"id":"5852477","hostname":"autoconfig","type":"CNAME","priority":"0","destination":"autoconfig.netcup.net","deleterecord":false,"state":"yes"},{"id":"13767728","hostname":"cluster","type":"A","priority":"0","destination":"185.170.113.121","deleterecord":false,"state":"yes"},{"id":"13767729","hostname":"cluster","type":"A","priority":"0","destination":"188.68.39.242","deleterecord":false,"state":"yes"},{"id":"11953281","hostname":"cluster","type":"A","priority":"0","destination":"185.170.115.235","deleterecord":false,"state":"yes"},{"id":"12064674","hostname":"cluster","type":"A","priority":"0","destination":"46.38.253.171","deleterecord":false,"state":"yes"},{"id":"5852476","hostname":"db","type":"A","priority":"0","destination":"188.68.47.16","deleterecord":false,"state":"yes"},{"id":"6058713","hostname":"extern","type":"CNAME","priority":"0","destination":"cluster.yamacore.de","deleterecord":false,"state":"yes"},{"id":"5924404","hostname":"intern","type":"CNAME","priority":"0","destination":"intern.yamacore.org","deleterecord":false,"state":"yes"},{"id":"5852473","hostname":"mail","type":"A","priority":"0","destination":"188.68.47.17","deleterecord":false,"state":"yes"},{"id":"5863014","hostname":"webmail","type":"A","priority":"0","destination":"188.68.47.17","deleterecord":false,"state":"yes"},{"id":"12061993","hostname":"Y-Cluster-VPS-Node1","type":"A","priority":"0","destination":"46.38.253.171","deleterecord":false,"state":"yes"},{"id":"11878885","hostname":"Y-Cluster-VPS-Node2","type":"A","priority":"0","destination":"185.170.113.121","deleterecord":false,"state":"yes"},{"id":"11878886","hostname":"Y-Cluster-VPS-Node3","type":"A","priority":"0","destination":"188.68.39.242","deleterecord":false,"state":"yes"},{"id":"11878887","hostname":"Y-Cluster-VPS-Node4","type":"A","priority":"0","destination":"185.170.115.235","deleterecord":false,"state":"yes"},{"id":"6058714","hostname":"yamacoreapp","type":"CNAME","priority":"0","destination":"cluster.yamacore.de","deleterecord":false,"state":"yes"},{"id":"36155407","hostname":"_acme-challenge","type":"TXT","priority":"0","destination":"uORcuU6WQEDV1FcGoKSJVhdRQ8Y-sNqvUke6jdY-V70","deleterecord":false,"state":"unknown"},{"id":"36155408","hostname":"_acme-challenge","type":"TXT","priority":"0","destination":"s6PFGSsVLw3i-JsqD-6n5pmK3LjgVFABGeAwxLN2nuA","deleterecord":false,"state":"unknown"}]}}
[Wed May 5 12:17:34 UTC 2021] {"serverrequestid":"NRQjDU03VVV252WOY6693D5Mjk08","clientrequestid":"","action":"updateDnsRecords","status":"success","statuscode":2000,"shortmessage":"DNS records successful updated","longmessage":"The given DNS records for this zone were updated.","responsedata":{"dnsrecords":[{"id":"15812934","hostname":" ","type":"A","priority":"0","destination":"46.38.253.171","deleterecord":false,"state":"yes"},{"id":"15812936","hostname":" ","type":"A","priority":"0","destination":"185.170.115.235","deleterecord":false,"state":"yes"},{"id":"15812937","hostname":" ","type":"A","priority":"0","destination":"185.170.113.121","deleterecord":false,"state":"yes"},{"id":"15812938","hostname":" ","type":"A","priority":"0","destination":"188.68.39.242","deleterecord":false,"state":"yes"},{"id":"5852469","hostname":"@","type":"A","priority":"0","destination":"188.68.47.15","deleterecord":false,"state":"yes"},{"id":"5852471","hostname":"@","type":"AAAA","priority":"0","destination":"2a03:4000:30:1f20::10:8047","deleterecord":false,"state":"yes"},{"id":"5852472","hostname":"@","type":"TXT","priority":"0","destination":"v=spf1 mx a include:_spf.webhosting.systems ~all","deleterecord":false,"state":"yes"},{"id":"5852474","hostname":"@","type":"MX","priority":"10","destination":"mail.yamacore.de","deleterecord":false,"state":"yes"},{"id":"5852475","hostname":"@","type":"MX","priority":"50","destination":"mx2f11.netcup.net","deleterecord":false,"state":"yes"},{"id":"5852477","hostname":"autoconfig","type":"CNAME","priority":"0","destination":"autoconfig.netcup.net","deleterecord":false,"state":"yes"},{"id":"13767728","hostname":"cluster","type":"A","priority":"0","destination":"185.170.113.121","deleterecord":false,"state":"yes"},{"id":"13767729","hostname":"cluster","type":"A","priority":"0","destination":"188.68.39.242","deleterecord":false,"state":"yes"},{"id":"11953281","hostname":"cluster","type":"A","priority":"0","destination":"185.170.115.235","deleterecord":false,"state":"yes"},{"id":"12064674","hostname":"cluster","type":"A","priority":"0","destination":"46.38.253.171","deleterecord":false,"state":"yes"},{"id":"5852476","hostname":"db","type":"A","priority":"0","destination":"188.68.47.16","deleterecord":false,"state":"yes"},{"id":"6058713","hostname":"extern","type":"CNAME","priority":"0","destination":"cluster.yamacore.de","deleterecord":false,"state":"yes"},{"id":"5924404","hostname":"intern","type":"CNAME","priority":"0","destination":"intern.yamacore.org","deleterecord":false,"state":"yes"},{"id":"5852473","hostname":"mail","type":"A","priority":"0","destination":"188.68.47.17","deleterecord":false,"state":"yes"},{"id":"5863014","hostname":"webmail","type":"A","priority":"0","destination":"188.68.47.17","deleterecord":false,"state":"yes"},{"id":"12061993","hostname":"Y-Cluster-VPS-Node1","type":"A","priority":"0","destination":"46.38.253.171","deleterecord":false,"state":"yes"},{"id":"11878885","hostname":"Y-Cluster-VPS-Node2","type":"A","priority":"0","destination":"185.170.113.121","deleterecord":false,"state":"yes"},{"id":"11878886","hostname":"Y-Cluster-VPS-Node3","type":"A","priority":"0","destination":"188.68.39.242","deleterecord":false,"state":"yes"},{"id":"11878887","hostname":"Y-Cluster-VPS-Node4","type":"A","priority":"0","destination":"185.170.115.235","deleterecord":false,"state":"yes"},{"id":"6058714","hostname":"yamacoreapp","type":"CNAME","priority":"0","destination":"cluster.yamacore.de","deleterecord":false,"state":"yes"},{"id":"36155408","hostname":"_acme-challenge","type":"TXT","priority":"0","destination":"s6PFGSsVLw3i-JsqD-6n5pmK3LjgVFABGeAwxLN2nuA","deleterecord":false,"state":"unknown"}]}}
[Wed May 5 12:17:35 UTC 2021] _ret='0'
[Wed May 5 12:17:35 UTC 2021] {"serverrequestid":"0UNDZZty=2VR4B2i2","clientrequestid":"","action":"logout","status":"success","statuscode":2000,"shortmessage":"Logout successful","longmessage":"Session has been terminated successful.","responsedata":""}
[Wed May 5 12:17:35 UTC 2021] Removed: Success
[Wed May 5 12:17:35 UTC 2021] d='yamacore.de'
[Wed May 5 12:17:35 UTC 2021] txtdomain='_acme-challenge.yamacore.de'
[Wed May 5 12:17:35 UTC 2021] aliasDomain='_acme-challenge.yamacore.de'
[Wed May 5 12:17:35 UTC 2021] _currentRoot='dns_netcup'
[Wed May 5 12:17:35 UTC 2021] txt='s6PFGSsVLw3i-JsqD-6n5pmK3LjgVFABGeAwxLN2nuA'
[Wed May 5 12:17:35 UTC 2021] d_api='/root/.acme.sh/dnsapi/dns_netcup.sh'
[Wed May 5 12:17:35 UTC 2021] Removing txt: s6PFGSsVLw3i-JsqD-6n5pmK3LjgVFABGeAwxLN2nuA for domain: _acme-challenge.yamacore.de
[Wed May 5 12:17:35 UTC 2021] POST
[Wed May 5 12:17:35 UTC 2021] _post_url='https://ccp.netcup.net/run/webservice/servers/endpoint.php?JSON'
[Wed May 5 12:17:35 UTC 2021] _CURL='curl --silent --dump-header /acme.sh/http.header -L '
[Wed May 5 12:17:35 UTC 2021] {"serverrequestid":"qXFXcDMUgDF0U=3nA","clientrequestid":"","action":"login","status":"success","statuscode":2000,"shortmessage":"Login successful","longmessage":"Session has been created successful.","responsedata":{"apisessionid":"UTkzNUM3OFQxNDI2NHZBbW9IYVRqR2JyU2ZCUm1RSTU0WUo1Mm"}}
[Wed May 5 12:17:35 UTC 2021] {"serverrequestid":"JuzQojARlcR61Y30=","clientrequestid":"","action":"infoDnsRecords","status":"success","statuscode":2000,"shortmessage":"DNS records found","longmessage":"DNS Records for this zone were found.","responsedata":{"dnsrecords":[{"id":"15812934","hostname":" ","type":"A","priority":"0","destination":"46.38.253.171","deleterecord":false,"state":"yes"},{"id":"15812936","hostname":" ","type":"A","priority":"0","destination":"185.170.115.235","deleterecord":false,"state":"yes"},{"id":"15812937","hostname":" ","type":"A","priority":"0","destination":"185.170.113.121","deleterecord":false,"state":"yes"},{"id":"15812938","hostname":" ","type":"A","priority":"0","destination":"188.68.39.242","deleterecord":false,"state":"yes"},{"id":"5852469","hostname":"@","type":"A","priority":"0","destination":"188.68.47.15","deleterecord":false,"state":"yes"},{"id":"5852471","hostname":"@","type":"AAAA","priority":"0","destination":"2a03:4000:30:1f20::10:8047","deleterecord":false,"state":"yes"},{"id":"5852472","hostname":"@","type":"TXT","priority":"0","destination":"v=spf1 mx a include:_spf.webhosting.systems ~all","deleterecord":false,"state":"yes"},{"id":"5852474","hostname":"@","type":"MX","priority":"10","destination":"mail.yamacore.de","deleterecord":false,"state":"yes"},{"id":"5852475","hostname":"@","type":"MX","priority":"50","destination":"mx2f11.netcup.net","deleterecord":false,"state":"yes"},{"id":"5852477","hostname":"autoconfig","type":"CNAME","priority":"0","destination":"autoconfig.netcup.net","deleterecord":false,"state":"yes"},{"id":"13767728","hostname":"cluster","type":"A","priority":"0","destination":"185.170.113.121","deleterecord":false,"state":"yes"},{"id":"13767729","hostname":"cluster","type":"A","priority":"0","destination":"188.68.39.242","deleterecord":false,"state":"yes"},{"id":"11953281","hostname":"cluster","type":"A","priority":"0","destination":"185.170.115.235","deleterecord":false,"state":"yes"},{"id":"12064674","hostname":"cluster","type":"A","priority":"0","destination":"46.38.253.171","deleterecord":false,"state":"yes"},{"id":"5852476","hostname":"db","type":"A","priority":"0","destination":"188.68.47.16","deleterecord":false,"state":"yes"},{"id":"6058713","hostname":"extern","type":"CNAME","priority":"0","destination":"cluster.yamacore.de","deleterecord":false,"state":"yes"},{"id":"5924404","hostname":"intern","type":"CNAME","priority":"0","destination":"intern.yamacore.org","deleterecord":false,"state":"yes"},{"id":"5852473","hostname":"mail","type":"A","priority":"0","destination":"188.68.47.17","deleterecord":false,"state":"yes"},{"id":"5863014","hostname":"webmail","type":"A","priority":"0","destination":"188.68.47.17","deleterecord":false,"state":"yes"},{"id":"12061993","hostname":"Y-Cluster-VPS-Node1","type":"A","priority":"0","destination":"46.38.253.171","deleterecord":false,"state":"yes"},{"id":"11878885","hostname":"Y-Cluster-VPS-Node2","type":"A","priority":"0","destination":"185.170.113.121","deleterecord":false,"state":"yes"},{"id":"11878886","hostname":"Y-Cluster-VPS-Node3","type":"A","priority":"0","destination":"188.68.39.242","deleterecord":false,"state":"yes"},{"id":"11878887","hostname":"Y-Cluster-VPS-Node4","type":"A","priority":"0","destination":"185.170.115.235","deleterecord":false,"state":"yes"},{"id":"6058714","hostname":"yamacoreapp","type":"CNAME","priority":"0","destination":"cluster.yamacore.de","deleterecord":false,"state":"yes"},{"id":"36155408","hostname":"_acme-challenge","type":"TXT","priority":"0","destination":"s6PFGSsVLw3i-JsqD-6n5pmK3LjgVFABGeAwxLN2nuA","deleterecord":false,"state":"unknown"}]}}
[Wed May 5 12:17:36 UTC 2021] _ret='0'
[Wed May 5 12:17:36 UTC 2021] {"serverrequestid":"N410N9k2ZwRDl3M3O58V63QGSzM7","clientrequestid":"","action":"updateDnsRecords","status":"success","statuscode":2000,"shortmessage":"DNS records successful updated","longmessage":"The given DNS records for this zone were updated.","responsedata":{"dnsrecords":[{"id":"15812934","hostname":" ","type":"A","priority":"0","destination":"46.38.253.171","deleterecord":false,"state":"yes"},{"id":"15812936","hostname":" ","type":"A","priority":"0","destination":"185.170.115.235","deleterecord":false,"state":"yes"},{"id":"15812937","hostname":" ","type":"A","priority":"0","destination":"185.170.113.121","deleterecord":false,"state":"yes"},{"id":"15812938","hostname":" ","type":"A","priority":"0","destination":"188.68.39.242","deleterecord":false,"state":"yes"},{"id":"5852469","hostname":"@","type":"A","priority":"0","destination":"188.68.47.15","deleterecord":false,"state":"yes"},{"id":"5852471","hostname":"@","type":"AAAA","priority":"0","destination":"2a03:4000:30:1f20::10:8047","deleterecord":false,"state":"yes"},{"id":"5852472","hostname":"@","type":"TXT","priority":"0","destination":"v=spf1 mx a include:_spf.webhosting.systems ~all","deleterecord":false,"state":"yes"},{"id":"5852474","hostname":"@","type":"MX","priority":"10","destination":"mail.yamacore.de","deleterecord":false,"state":"yes"},{"id":"5852475","hostname":"@","type":"MX","priority":"50","destination":"mx2f11.netcup.net","deleterecord":false,"state":"yes"},{"id":"5852477","hostname":"autoconfig","type":"CNAME","priority":"0","destination":"autoconfig.netcup.net","deleterecord":false,"state":"yes"},{"id":"13767728","hostname":"cluster","type":"A","priority":"0","destination":"185.170.113.121","deleterecord":false,"state":"yes"},{"id":"13767729","hostname":"cluster","type":"A","priority":"0","destination":"188.68.39.242","deleterecord":false,"state":"yes"},{"id":"11953281","hostname":"cluster","type":"A","priority":"0","destination":"185.170.115.235","deleterecord":false,"state":"yes"},{"id":"12064674","hostname":"cluster","type":"A","priority":"0","destination":"46.38.253.171","deleterecord":false,"state":"yes"},{"id":"5852476","hostname":"db","type":"A","priority":"0","destination":"188.68.47.16","deleterecord":false,"state":"yes"},{"id":"6058713","hostname":"extern","type":"CNAME","priority":"0","destination":"cluster.yamacore.de","deleterecord":false,"state":"yes"},{"id":"5924404","hostname":"intern","type":"CNAME","priority":"0","destination":"intern.yamacore.org","deleterecord":false,"state":"yes"},{"id":"5852473","hostname":"mail","type":"A","priority":"0","destination":"188.68.47.17","deleterecord":false,"state":"yes"},{"id":"5863014","hostname":"webmail","type":"A","priority":"0","destination":"188.68.47.17","deleterecord":false,"state":"yes"},{"id":"12061993","hostname":"Y-Cluster-VPS-Node1","type":"A","priority":"0","destination":"46.38.253.171","deleterecord":false,"state":"yes"},{"id":"11878885","hostname":"Y-Cluster-VPS-Node2","type":"A","priority":"0","destination":"185.170.113.121","deleterecord":false,"state":"yes"},{"id":"11878886","hostname":"Y-Cluster-VPS-Node3","type":"A","priority":"0","destination":"188.68.39.242","deleterecord":false,"state":"yes"},{"id":"11878887","hostname":"Y-Cluster-VPS-Node4","type":"A","priority":"0","destination":"185.170.115.235","deleterecord":false,"state":"yes"},{"id":"6058714","hostname":"yamacoreapp","type":"CNAME","priority":"0","destination":"cluster.yamacore.de","deleterecord":false,"state":"yes"}]}}
[Wed May 5 12:17:36 UTC 2021] POST
[Wed May 5 12:17:36 UTC 2021] _post_url='https://ccp.netcup.net/run/webservice/servers/endpoint.php?JSON'
[Wed May 5 12:17:36 UTC 2021] _CURL='curl --silent --dump-header /acme.sh/http.header -L '
[Wed May 5 12:17:36 UTC 2021] {"serverrequestid":"=d1jdRg5WbMIrTE0D","clientrequestid":"","action":"logout","status":"success","statuscode":2000,"shortmessage":"Logout successful","longmessage":"Session has been terminated successful.","responsedata":""}
[Wed May 5 12:17:36 UTC 2021] Removed: Success
[Wed May 5 12:17:36 UTC 2021] Verify finished, start to sign.
[Wed May 5 12:17:36 UTC 2021] i='2'
[Wed May 5 12:17:36 UTC 2021] j='16'
[Wed May 5 12:17:36 UTC 2021] Lets finalize the order.
[Wed May 5 12:17:36 UTC 2021] Le_OrderFinalize='https://acme-staging-v02.api.letsencrypt.org/acme/finalize/19389032/46298443'
[Wed May 5 12:17:36 UTC 2021] url='https://acme-staging-v02.api.letsencrypt.org/acme/finalize/19389032/46298443'
[Wed May 5 12:17:36 UTC 2021] payload='{"csr": "MIICojCCAYoCAQAwGDEWMBQGA1UEAwwNKi55YW1hY29yZS5kZTCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBAOVJcjhjIIROVPXpM56EOWLDcoVeuBX6XmwzFlL8fvLBmsyhyWIjSeOpa7ooErfOj24221vtIM_dNIpVv-Rv8SP2b9v25AWE41CNlThcGG_YszQusDgygg5Sxb-jhoH6J4C-xftwzwje4qujTLjDMdgihBpPfaACv0fEQPFS9UfdwFXPj5RJPFYbe3TGEbzmpjiZmDfiyeeR3TzOgHkL2h5w5-DDVjRACiDhbbUVMmKQZnxXaCKjLV16Rq6M0D0D_w48sq4UWbYW-Ts7SefkANlotsZqWLo6wzu43Ah7y-HJI8z9oIsioo9zrSK86sHZvJobmzWwTgW874Sx1SZho8ECAwEAAaBFMEMGCSqGSIb3DQEJDjE2MDQwCwYDVR0PBAQDAgXgMCUGA1UdEQQeMByCDSoueWFtYWNvcmUuZGWCC3lhbWFjb3JlLmRlMA0GCSqGSIb3DQEBCwUAA4IBAQB1y8_8yLPseyDVBSIRYarCI5dD-8aDU33Xp-_YquFxErE6kiGsbHmEpOCA04V9_3Hl1s82BVvVVidPZBux2LqOYQ7H1wgOHtVfFkbqa1jaGyDUMywt3_Bs9YMzXRGSF_AqYBJOo3uDfFe3jfayI2Dx6Aa6hTstqx42oI_CrMdP0lmXL2voK0_ADRa9hJa7LSXNf8TWA-hqGhuPZ85OVXvhF6gHaXLpBzLvLjvW_S_nTEzzzNm6PpgzXh9YS0pyszvKDnfZ62A8ks30mt0d9LZVR0WaEpaup4eYmHtcwcTPeWmkrmuXXag0POeIbUImyAgvlo1B0RX80rMpqE0-yd5e"}'
[Wed May 5 12:17:36 UTC 2021] _post_url='https://acme-staging-v02.api.letsencrypt.org/acme/finalize/19389032/46298443'
[Wed May 5 12:17:37 UTC 2021] _ret='0'
[Wed May 5 12:17:37 UTC 2021] code='403'
[Wed May 5 12:17:37 UTC 2021] Sign failed, finalize code is not 200.
[Wed May 5 12:17:37 UTC 2021] {
"type": "urn:ietf:params:acme:error:orderNotReady",
"detail": "Order's status ("invalid") is not acceptable for finalization",
"status": 403
[Wed May 5 12:17:37 UTC 2021] _on_issue_err
[Wed May 5 12:17:37 UTC 2021] Please add '--debug' or '--log' to check more details.
[Wed May 5 12:17:37 UTC 2021] See: https://github.com/acmesh-official/acme.sh/wiki/How-to-debug-acme.sh
[Wed May 5 12:17:37 UTC 2021] Diagnosis versions:
openssl:openssl
OpenSSL 1.1.1k 25 Mar 2021
apache:
apache doesn't exist.
nginx:
nginx doesn't exist.
socat:
socat by Gerhard Rieger and contributors - see www.dest-unreach.org
socat version 1.7.3.4 on Jan 6 2020 03:35:53
running on Linux version #1 SMP Debian 4.19.181-1 (2021-03-19), release 4.19.0-16-amd64, machine x86_64
features:
#define WITH_STDIO 1
#define WITH_FDNUM 1
#define WITH_FILE 1
#define WITH_CREAT 1
#define WITH_GOPEN 1
#define WITH_TERMIOS 1
#define WITH_PIPE 1
#define WITH_UNIX 1
#define WITH_ABSTRACT_UNIXSOCKET 1
#define WITH_IP4 1
#define WITH_IP6 1
#define WITH_RAWIP 1
#define WITH_GENERICSOCKET 1
#define WITH_INTERFACE 1
#define WITH_TCP 1
#define WITH_UDP 1
#define WITH_SCTP 1
#define WITH_LISTEN 1
#define WITH_SOCKS4 1
#define WITH_SOCKS4A 1
#define WITH_PROXY 1
#define WITH_SYSTEM 1
#define WITH_EXEC 1
#define WITH_READLINE 1
#define WITH_TUN 1
#define WITH_PTY 1
#define WITH_OPENSSL 1
#undef WITH_FIPS
#undef WITH_LIBWRAP
#define WITH_SYCLS 1
#define WITH_FILAN 1
#define WITH_RETRY 1
#define WITH_MSGLEVEL 0 / debug /
The operating system my web server runs on is (include version): no webserver
My hosting provider, if applicable, is: netcup
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): acme.sh [ 2.8.9], same problem with latest traefik
tried multible times with staging and non staging both the same output, over days now
Its fixed now, the problem was at acme.sh a new version fixed it
