ytc1-cloud.dyndns.org ytc1.dyndns.org
./acme.sh --issue -d ytc1.dyndns.org --use-wget --test --apache --accountconf ${PWD}/account.conf
[Monday, 9 March 2020 at 14:13:09 GMT] Using stage ACME_DIRECTORY: https://acme-staging-v02.api.letsencrypt.org/directory
[Monday, 9 March 2020 at 14:13:10 GMT] Checking if there is an error in the apache config file before starting.
[Monday, 9 March 2020 at 14:13:10 GMT] OK
[Monday, 9 March 2020 at 14:13:10 GMT] JFYI, Config file /etc/apache2/2.4/httpd.conf is backuped to /root/.acme.sh/httpd.conf
[Monday, 9 March 2020 at 14:13:10 GMT] In case there is an error that can not be restored automatically, you may try restore it yourself.
[Monday, 9 March 2020 at 14:13:10 GMT] The backup file will be deleted on success, just forget it.
[Monday, 9 March 2020 at 14:13:11 GMT] Single domain=‘ytc1.dyndns.org’
[Monday, 9 March 2020 at 14:13:11 GMT] Getting domain auth token for each domain
[Monday, 9 March 2020 at 14:13:14 GMT] Getting webroot for domain=‘ytc1.dyndns.org’
[Monday, 9 March 2020 at 14:13:14 GMT] Verifying: ytc1.dyndns.org
gsed: -e expression #1, char 31: Invalid content of {}
[Monday, 9 March 2020 at 14:13:18 GMT] ytc1.dyndns.org:Verify error:
[Monday, 9 March 2020 at 14:13:18 GMT] Please check log file for more details: /var/www/acme/.acme.sh/acme.sh.log
Apache 2.4
Solaris 11.4
Yes
No
v2.8.6
I’m (fairly) certain I have my Virtualhost and Alias set up ok.
I’ve also updated the php to “whitelist” both WWWs.
History is that I have had 2 certs (which I know now is incorrect) going via 1 dyndns.
Each Apache runs in a separate S11.4 zone.
My “main” use is the ytc1-cloud.dydndns.org on port 643 and I direct that + port 80 to the my nextcloud server.
I am trying to create a certificate that is valid on both servers (as ytc1-cloud.dydndns.org and ytc1,dyndns.org). As per earlier help requests I have sorted out some misconceptions I had over the way acme is working.
If I update ytc1-cloud.dyndns.org , that works ok.
When I try to issue with ytc1.dyndns.,org as a -d , I get the above fail.
If I run with ytc1-cloud.dyndns.org it asked me to force
Where do I look next ? in my apache log I am getting this
—8<
[Mon Mar 09 14:06:56.529549 2020] [authz_core:error] [pid 5038] [client 18.224.20.83:57902] AH01630: client denied by server configuration: /home/.acme
[Mon Mar 09 14:06:56.676595 2020] [authz_core:debug] [pid 5037] mod_authz_core.c(817): [client 34.211.60.134:32622] AH01626: authorization result of Require all denied: denied
[Mon Mar 09 14:06:56.676663 2020] [authz_core:debug] [pid 5037] mod_authz_core.c(817): [client 34.211.60.134:32622] AH01626: authorization result of : denied
[Mon Mar 09 14:06:56.676674 2020] [authz_core:error] [pid 5037] [client 34.211.60.134:32622] AH01630: client denied by server configuration: /home/.acme
[Mon Mar 09 14:06:56.727537 2020] [authz_core:debug] [pid 5041] mod_authz_core.c(817): [client 66.133.109.36:61544] AH01626: authorization result of Require all denied: denied
[Mon Mar 09 14:06:56.727600 2020] [authz_core:debug] [pid 5041] mod_authz_core.c(817): [client 66.133.109.36:61544] AH01626: authorization result of : denied
[Mon Mar 09 14:06:56.727611 2020] [authz_core:error] [pid 5041] [client 66.133.109.36:61544] AH01630: client denied by server configuration: /home/.acme
—8<
Not sure if that is a clue, however I have never have a /home/.acme
for the 1st domain listed
